Question about Ricoh Priport VT6000 Copier
I have a Ricoh PriPort 6000 that has recently quit feeding and printing envelopes. It still prints everything except envelopes. Any suggestions on how to fix this? Carol720
  • 1,110 Answers
If it is not feeding the envelope at all then the first step would be to clean the feed roller. You can use a cloth and some glass cleaner to clean the tire. Envelopes are among the hardest things to feed and if the tire has any paper dust build up it can cause feeding problems. Feed tire replacement may be necessary if cleaning does not completely solve the feeding problem.
Good Luck and Thank You for using Fixya.
Posted on Jan 03, 2011
I want to print envelopes 11/23
You can ask manufacturer for Envelope printing options they may Additional Separate Trays for this or use the existing tray with Envelope adjustment
Jun 25, 2015 | Ricoh Aficio Mp C5000 Color Copier - 129k...
How do I prevent envelopes from getting creased on a Ricoh MP c3500?
Hopefully you are using the bypass when printing them. Creasing is only caused by two things. Moisture in the paper and uneven fusing. Make sure when you are printing them you select thick 2 in the printer properties pull down menu. If the problem continues switch the feed direction and possibly the brand of envelopes. The same thing applies to printing labels (the thick 2 setting will provide the necessary heat to properly fuse the toner). But when copying, push the # key and select thick paper from the menu there.
Nov 21, 2014 | Ricoh Aficio MP C3501 Multifunction Color...
Jam on ricoh priport jp5000
Page 190 of the manual has some places to check:
http://www.manualslib.com/manual/140763/Ricoh-Priport-Jp5000.html?page=190#manual
Dec 14, 2013 | Office Equipment & Supplies
Ricoh priport vt 3800
when it print remove some of letter
Jun 11, 2013 | Office Equipment & Supplies
Problems printing envelopes envelopes come out blank. No manual feed prompt. Documents print fine.
Has anyone contacted you yet about this? I am having this problem except I do get a manual feed prompt and (dude) it's a Dell.
Jul 17, 2010 | Brother MFC-7340 All-In-One Laser Printer
Paper jam message, remove the paper from drum
Try cleaning the feed rollers with soap and water and a damp cloth and see if your situation improves. sounds like the machine is missfeeding but your description was a little vague.
If it does improve youll need new rollers.
Also try flipping the paper over to see if improves.
Lastly does the paper size displayed on the screen match what is actually loaded? if not... correct as nessesary
Good luck
Apr 18, 2010 | Ricoh Office Equipment & Supplies
Ricoh laser printer will not correctly print my envelopes - need someone to help me calibrate the printer or the word program to effectively print envelopes
what model? you must tell the printer what envelope type is in the bypass (must use bypass) usually type 10. also must tell word in print properties to feed from bypass, again usually type 10 envelopes
Aug 04, 2009 | Computers & Internet
How to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Nov 19, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
Printing envelopes on HL4040CN
I just bought a HL-4040CN and all my envelopes wrinkled, regardless of the size, paper thickness or software settings (thin envelope, thick envelope, etc.). Here's how I solved the problem....Open the rear panel and you'll notice a small gray lever on each side, which is probably pointing to "A" on the scale (A, B, Envelope). Move both levers to "Envelope" and close the back panel. The troubleshooting manual says the levers should be moved back to "A" after printing the envelopes, but I left them in the Envelope position and can't see any difference when printing regular or test pages or envelopes, except the envelopes are no longer wrinkled. I called Brother and asked them if there was any reason why the levers can't stay in the Envelope position, and they told me they could be left there if it wasn't negatively affecting other documents. Now, I have a great printer that prints everything without any problems. Hope this helps.
Sep 08, 2008 | Brother HL-2040 Laser Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
83 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
