Question about Sony VAIO VGN-AR270 Notebook
Windows XP is corrupted; therefore, It will not boot-up. I do not have CDs to reinstall XP :(
  • 98 Answers
My first advice is to take it to a technician and ask him to reinstall XP with your serial.
My second advice is to download an ISO, and burn it to a CD/DVD to install XP, but i don't recommend this.
Ask a friend of yours that is good in computers.
Posted on Jan 02, 2011
How do I recover or repair bootini and bootsect for Windows XP Professional after uninstalling Windows 7 Ultimate?
It's good that you have the recovery cds. Do NOT reformat the hard drive. Restore with the cds so you'll have a clean install . You will need to have any software cds that did not come with the original pc in order for them to rebuild the registry entries. That is the easiest way because there won't be any left over files from Windows 7 after you restore to XP.
Jan 24, 2014 | Computers & Internet
Tip
How to restore damaged system boot file.
When Windows system boot file is corrupted, the best thing to do is reinstalling the system.
This can be done either using original recovery CD, or using Windows setup disk.
To preserve your data you will need to chose partial recovery or upgrade setup.
Windows CDs has also a tool called Recovery Console that can be used to repair this kind of problems.
Here the procedure to fix the problem using Windows Recovery Console:
  • Insert Windows Setup CD, then start the computer.
  • When Welcome to Setup screen appears, press R.
  • When asked, chose the Windows installation you wish to repair (eg 1) , then press Enter.
  • When prompted, enter the administrator password .
  • When command prompt (DOS screen) starts, enter the following commands./ (if C: is not your Windows system drive, then change the drive letter)
    ATTRIB -H -R -S C:BOOT.INI
    DEL C:BOOT.INI
    BOOTCFG /REBUILD FIXBOOT
  • Remove the Windows CD from drive and restart computer.
on Sep 10, 2009 | Microsoft Windows XP Professional
I have a dual boot drive. C has windowds 7 and d has windows xp. Windows 7 on C works fine. However I can't boot into Window XP. I get an error saying the process has been stopped in order to protect...
Hello.
Just some thoughts:
1. Your Windows XP install (image ?) may be corrupt. Reinstall or capture another image.
2. Try installing Windows XP on C: and Windows 7 on D: That way the boot files are left for the older version.
Hope this helps.
Jan 01, 2011 | Computers & Internet
<windows root>\system32\hal.dll
Did you buy from an original dealer, because i still use the same laptop and 2 cds came along with a spare battery and a spare charger.
But you can solve this problem, you just need to get hold of a  windows xp service pack 1 bootable cd.
Then insert the cd and boot through the cd.
for this you have to set boot priority number 1 to your dvd/cd drive,go to bios and under the boot settings set the priority as mentioned and then save and restart with this cd in the drive.
Now the system will boot through the cd, now in the main screen select repair option, this will repair all the missing and corrupt files.
Jun 25, 2010 | Dell Latitude D600 Notebook
Windows could not start because the following file is missing or corrupt: windowssystem32configsystem
only one solution: reinstall windows using the Dell Recovery CDs that came with the computer.
Jan 18, 2010 | Dell Inspiron 2200 Notebook
When i turn on my laptop it says invalid system disk.replace the disk and then press any key
You probably are using Windows XP. With this error, you must re install your Windows XP operating system with your XP CD.
Oct 21, 2009 | Computers & Internet
Error message when starting up: <Windowsroot>\system 32\hal.dll. Please reinstall a copy of the above file.
This issue happens if boot files are corrupted .. you need to have the Operating System Cd to resolve this problem . Considering you have windows xp you need to have the installation cd for windows xp .
you need to use bootcfg command to resolve the issue.
Go to bios and change the boot sequence to boot from the cd, if you are not able to boot from the cd. and then boot using windows xp cd .
Then push R to go to recovery console and use the below command
Boot to Recovery Console and rebuild the BOOT.INI file with the BOOTCFG /REBUILD
command.
May 09, 2009 | Microsoft Windows XP Media Center Edition...
Computer won't boot
hi there,
in this case you mention that it check then system configuration and then goes blank,so therefor your windows XP installer is corrupted replace your windows installer.regards and have a nice day don't forget to rate me.
Apr 08, 2009 | Computers & Internet
.exe files got corrupted
well, if the CD won't read in Windows, and this is due to a virus, it should not affect the drives functionality before windows loads. You will need to use a bootable CD (like the Windows CD) and when you power on hte computer, enter the boot menu (check bottom of screen during power up for the correct button.) then select CD ROM and see if it will boot to Windows Set up. If it will, exit setup, restart windows, back up your data to a jump drive and then reboot with the CD & boot menu selection, and reload windows. Before you do any of this, go to acer's website and download all of the drivers for your computer to a jump drive, you will need them for the windows reinstall
Jan 08, 2009 | Microsoft Windows XP Professional With...
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Sony VAIO VGN-AR270 Notebook Logo
27 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
