Question about Fujitsu Heating & Cooling
We have a fujitsu inverter that is wall mounted - model ASTA 09LCC. The fan is working but the air is not cooling. There is a green timer light that periodically flashes 3 times. Any suggestions?
  • 2,133 Answers
E3 Outdoor activation of high pressure switch.
Check condenser coil. If blocked, clean it. If out door fan rpm less replace capacitor. Helpful?
Posted on Jan 02, 2011
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
I have a fujitsu inverter asta 24jcc every eight seconds the red and green light flashes about five times
the problem with the electronic ones is they usually need repairing by a service centre or aircon guy and if it's not under warranty they'll be able to recommend their repairer. We had a similar fault where there was just some random code error. It happened during a heat wave and it turned out the fan motor seized and the board got burnt out. They had to replace they board so that may be what you're up for.
Dec 14, 2014 | Fujitsu Heating & Cooling
Hi Ken,
I hope the following link will help you?
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Dec 13, 2014 | Fujitsu Heating & Cooling
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
Flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Jan 07, 2008 | Heating & Cooling
Heating & Cooling Logo
533 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
