Question about Dryers
Door switch bad how to replace - Dryers
  • seth adams Jan 02, 2011
    What is your model number
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Here is a video to walk you thru the repair.
Posted on Jan 02, 2011
Microwave gives a door fault and will not start. I replaced the door switches still get same message of door
Some switches have positional adjustments, or your logic/control board is bad and showing a door problem when there is none. Could also be a bad wire to a switch.
Aug 29, 2017 | Microwave Ovens
Door ajar light is on and inside light will not shut off when all doors are shut?
Most likely it is a bad switch/relay on the door. You should be able to actuate the switch with your finger when the door is open. If nothing happens when you push the switch in and out then its possible that you may need to replace the switch. You might first try removing the switch and checking it to see if it is stuck and make sure the wiring is connected securely. Your local Chrysler Dealership should have the replacement part and could replace it for you if you feel like its something you don't want to tackle.
Feb 18, 2012 | 2000 Chrysler Town & Country
Interior light won't turn off with ignition off keys out and all doors shut. Causes?
The door switch is gone bad or got dirty.In some cases cleaning helps,other wise it needs replacement. first try cleaning:--The door ajar and dome light switch is made in the door latch,get a wd-40 spray bottle. Open your door and spray into the door latch liberally and close and open the door about 6-7 times do this three or four times both doors if that doesn't work have it replaced either switch or switch and latch assembly
------------- you need a new door jam switch for it ,its the one that shuts the light off when the door is always shut on it,they go bad like this.---------- This will help. thanks.Helpmech.
Feb 19, 2011 | 1998 Ford Ranger SuperCab
Door ajar lite comes on and the alarm keeps dinging all doors are in line and closed how to make the ding stop?
first of all, you may have one or more door buttons that are bad. spray all door switches with a good spray lubricant and see if this helps. if not, find bad one and replace it. if door switches are bad door ajar light will think door is still open.
Aug 14, 2010 | 1994 Dodge Caravan
When I push the start button on my kenmore dryer it will not start and the drum will not turn
Several part failures can cause this symptom: bad start switch, bad door switch, broken belt, bad timer, bad thermal fuse, etc.
Most likely, the door switch or start switch is the problem.
Unplug the dryer! Check the door switch for continuity, when the door is closed, with a multimeter. If it does not have continuity when the door is closed, replace it. The start switch should have continuity only when it is pressed or rotated (as if trying to start the machine).
Apr 19, 2010 | Kenmore 63942 Dryer
2000 VW Beetle interior lights don't come on when drivers door
The drivers side door latch is bad. Just replaced one in my daughters 99 beetle. $184 dealer part. same thing no lights then alarm will mgo off for no reason, lights will come on at random times while driving, no chime when key is in.
Mar 06, 2010 | 2000 Volkswagen Beetle
Lights in refrigerator stay on when doors are closed
take a putty knife and pry out the door switch from its resting place in the door,take some electrical cleaner and clean and lube it then try it again,if it still doesn't make/break connection,replace it,a lot of times they just get sticky from spills and dirt,etc
Feb 04, 2010 | LG LFX25960 Bottom Freezer French Door...
The dome lights wont come when the doors are open, i can manuelly turn them on though.
The drivers side door jab is bad,it has effect on the other doors also,if it malfunctions.
Jan 24, 2010 | 1999 Chevrolet Tahoe
Microwave Problem
I would say it's most likely a bad door switch or switch mount or a bad connection on the magnetron or a bad magnetron.
But generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 24, 2007 | Microwave Ovens
Dryers Logo
26 people viewed this question
Top Dryers Experts
