Question about Armitron Digital Sport #45/6967PNK Watch
How do i set the time - Armitron Digital Sport #45/6967PNK Watch
How to set time on polar rs300x
Access watch settings scrolling by UP/Down button.
<Settings> <Ok> <Watch> <Time and Date Settings>
In Time Settings:
Set the local time (Time 1) and a time difference to it (Time 2).
With Time zone, you can select which time zone is used.
In Time view, you can easily change the time zone from Time 1 to Time 2 by pressing and holding DOWN.
Set the date with Date setting.
You can also download the user manual from the link below
http://www.polar.com/e_manuals/RS300X/Polar_RS300X_user_manual_English.pdf
Oct 06, 2015 | Polar RS300X Watch
Can't set the digital time on Diesel DZ721
here are instructions from diesel:
http://store.dieseltimeframes.com/wcsstore/CommonDiesel/instructions/ENGLISH/Diesel_Digital-Guide_ENG.pdf
more specifically
TIME OF DAY MODE
1. Press C to toggle between Time 1 and Time 2.
2. Hold C for two seconds to set Time 1 or 2 as default.
3. Press D to turn on/off key tone.
Time 1
> To set Time, press A until hour flashes. Press B to select the setting
item. Use C and D buttons to adjust the values up or down. Press A to
exit set mode.
Time 2
item. Use C and D buttons to adjust the values up or down. Press A to exit set mode.
> The range difference between Time 1 and Time 2 is 23 hours.
CHRONO MODE
1. Press C to start and stop chronograph.
2. Press D to Split/Reset the chronograph.
3. Press A to recall the memory if Chronograph is stopped.
4. Press A again to view the next lap.
5. Press C or D to exit Recall mode and go back to Chronograph mode.
6. There are a total of 10 lap memories.
TIMER MODE
1. There are 3 different modes of timer: Count Down-Stop, Count DownRepeat, Count Down-and Up.
2. Press C to start/stop the timer counting.
3. Press D to reset the counter to the preset value if timer is stopped.
4. Press and hold A for 2 seconds to enter Timer Setting Mode. 35 Timer Setting Mode
5. Press B to cycle around the setting item: timer-type, hour, minute,
second and to back timer-type again.
6. Press C and D to increase/decrease the setting value.
7. Press A to exit the setting mode.
TIMER ALARM
Timer alarm will beep 2 times a second for 30 seconds.
ALARM MODE
1. Press C to select the alarm.
2. Press D to enable/disable the alarm.
3. Press B to change to Time mode again.
ALARM SETTING MODE
1. Press and hold A for 2 seconds to enter the alarm settings mode.
2. Press C and D to increase or decrease the settings value.
3. Press A to exit the settings mode.
Nov 19, 2012 | Watches
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
How to set the time and analog time of CASIO ILLUMINATOR0 SGW 400 h
set the digital time: press and hold upper left button, then the seconds blinks use the lower left button to choose what are you going to set ( the one that blinks is the one that can be set ), use the upper right button to set. when your done. press the upper left button once.; set the analog time: from the time mode of the digital press mode until you see the "H.SET" , then the time of the digital appears, then use the upper right button to set the analog time, when your done just press the upper left button once and use the lower left button to bring back the time mode. i hope this will help you a lot.
Aug 13, 2011 | Watches
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
How do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Jul 26, 2010 | Fossil JR9455 Watch
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 | Watches
Cannot set the analog time on the Casio 2747.
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
May 25, 2009 | Casio AW80-7AV Wrist Watch
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
Armitron Digital Sport #45/6967PNK Watch Logo
51 people viewed this question
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Michael Vincent Cruz
Are you an Armitron Watch Expert? Answer questions, earn points and help others
