Question about GE Spacemaker JVM1640SJ Microwave Oven
Have Spacemaker Microwave--JVM1630WB 004. started cooking ,heard a POP!! , and it did not cook the food. smelled like burnt wires or capacitor. No fire. fuse did not blow. Any suggestions ?
I had the same thing happen to my 20 year old Frigidare microwave (it was 8 years old at the time). Same POP!, same failure. Though I'm handy with electrical, I don't mess around with the innards of a microwave. There are lethal doses of electricity stored in some capacitors even when the device is unplugged. I took mine to an appliance repair shop that works on microwaves. In my case, a high-end capacitor had blown. The repair cost me $80.00. $5.00 for the part, $75.00 for the labor. My microwave is still working 12 years later.
My solution is not pleasant. If you call a tech out to your house, his charge for labor and parts will probably be more than the cost of a new microwave. Taking it to a repair shop is cheaper, but you would want an estimate first which in itself will not be free of charge.
New microwaves have come down in price over the years. Countertop models for as little as $100.00. Over the range models starting at about $250.00.
Whatever you decide, this is going to cost you some money. Your microwave is dead. Good luck and hope I've helped a bit.
Posted on Jan 02, 2011
How to set power settings
Set the time as you normally would to cook your food: i.e. 60 seconds. Hit the power button; 100 will pop up on the screen, as in 100 % of power, enter 50 for 50% power, 70 for 70% etc. Food will cook more evenly this way, not burnt to a crisp on the outside, cold in the center.
Mar 13, 2013 | Rival Rgst902 Microwave Ovens
GE Spacemaker SL 1800 arching
Get some warm soapy water and clean inside making sure there are no food particals, if no change! the magnetron may be breaking down.
Mar 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Have a GE "Spacemaker II Sensor" microwave oven. When we try to cook now, it trys but the food does not get hot. Something is getting hot becasue there is a distinctive smell, perhaps like a burnt IC or...
you will need to find the source of the burning. it could be a cheap fix or more involved depending on the component. it could be a transformer, h.v.diode, magnetron, etc. if the diode is shorted, there is a good chance magnetron is defective too.
Aug 31, 2010 | GE Profile Spacemaker II PEM31 Microwave...
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker (JVM1871SK) 1800 Microwave doesn't microwave
Remove the case and see if you can localize the smell. Likely suspects are a shorted high voltage diode (replace) or a shorted stirrer bearing (replace stirrer)--a fan-like device located within the sheet metal waveguide near where the microwaves enter the cooking cavity. Make sure to have a cup of cold water in the cooking cavity when looking for problems. The problem could also be the high voltage transformer or the high voltage capacitor, but these are more rare problems. There are no radiation problems with the case off, but there are high voltages associated with the magnetron and it's power supply.
Oct 08, 2009 | GE Profile Spacemaker 1.8 Cu. Ft....
Microwave works perfectly but does not heat
Sadly your microwave has done it's last cooking. The mechanism you need to make it cook again would cost you more than a replacement microwave.
Jul 15, 2009 | GE Countertop Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Quit heating
This is a sure sign that the Magnatron has burnt out and needs replaced ( This is what cooks the food!) Replace magnatron in oven unit and all should work well!
Please rate my response!
THANK YOU!
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Runs but makes a super load pop sound with flame
It sounds like you're saying a flame and pop came out of the area where the internal electronics are? If that's the case, then I would suspect a failed high-voltage transformer, bad magnetron or that another high-voltage component is arcing, like maybe damaged wiring, but that's rare unless... ... I hate to suggest it, but maybe a "critter" has made his way into the high-voltage section! That can cause some really "interesting" effects! If the flame and pop are coming out of the cooking cavity, then it could be food debris or grease underneath the waveguide cover or in the waveguide. I would say the likliest cause is a failed HV transformer. If it's still under warranty, I'd call Sears right away to verify that. If it's not under warranty, you may want to pull it from the wall yourself and take it in to Sears or another shop yourself. You'll probably save about $50 as opposed to letting them come out to the home to service it.
Oct 04, 2006 | Kenmore 62642 / 62644 / 62649 Microwave...
GE Spacemaker JVM1640SJ Microwave Oven Logo
500 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
