Question about Simer ACE5S ACE5S Pump Well 1/2HP Ace 5S
Pump Housing is cracked. Can I replace the pump housing only?
    Problem Solver:
  • 15 Answers
U could if u found a used housing. U could ck a pump service co to c if they had 1 laying around.
Posted on Jan 02, 2011
    Genius:
  • 1,015 Answers
To the best of my knowledge the housing is available seperatly but it is not cost effective in my estimation. I would try to use a epoxy type glue such as pro-poxy 20 or J.B weld and try to repair it. Hope this helps you and thanks.
Cracked water pump
You should be able to replace the housing if you contact the manufacturer.
Mar 12, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Leaks from the pump housing
PUMP HOUSING LEAKS.. 3 THINGS COME TO MIND.# 1 IS THE SHAFT SEAL #2 IS THE TANK GASKET IS BAD, OR THE DREADED TANK BODY IS CRACKED. NOT UNCOMMON FOR THESE PUMPS. TAKE PUMP APART (MOTOR OFF) LET SIT AND DRY A LITTLE AND YOU WILL NEED TO LOOK CLOSE AND THE CRACKS STICK OUT BETTER WHEN SLIGHTLY DRY. IF IT IS CRACKED, THERE IS NO FIXING IT WITH GLUE. IT MUST BE REPLACED. IF IT COMES TO THAT POINT , I WOULD RECOMMEND A STA RITE DURA GLASS . 1 HP. THE SUPER PUMP YOU HAVE IS NOT THAT EFFICIENT. THEREFORE I RECOMMEND THE SR 1 HP. IT WILL SAVE YOU ON POWER ALSO , HEY YOU .. REMEMBER TO PRIME THE PUMP AFTER ANY PUMP REPAIR !!!... JAY FLORIDA
Jun 09, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
This June, I had to replace my strainer housing on my Hayward Power-Flo Matrix pump. It cracked in cold weather before I remembered to remove it. On installing a replacement, I noticed that the pump showed...
One or more of a couple issues is at play here. First would be the seal replacement. Even if you used the correct seal if you touched the surfaces or failed to install it properly it can and will leak. Second, inspect the housing around the seal fit and the stem of the impeller for cracks. A hairline crack is enough when placed under pump operating pressure to allow a leak. Somewhere in there is your solution.
John
Jul 17, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Pump housing is cracked and lealing. Is there any
the pump housing is available through your local pool dealer. It is broken down into 3 sections the pump, housing and Pod.
The Pool Tech
Jul 01, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
I have a water leak from where motor meets the housing (housing gasket) even after I replaced it (housing gasket). I don't notice any crack in casing. What did I do wrong?
Your seal plate could be warped or check for dirt at the base of the housing when you take it apart also check the brass gromets the six bolts screw into on the main housing. If these are pulled out at all you will need to replace the housing.
Jun 26, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
My daughter has a 2000 ford focus and she says that she is losing antifreeze in the back of her motor on the drivers side, is that where the water pump is?
The water pump should be on the passenger side with all accessory belt and all the pulleys. There's actually a thermostat housing on the driver's side of the engine. It's most likely that the housing has cracked at the seal. The seal sits in in a groove in the housing. The plastic housing is about 1mm thick at the seal and is known to break
Nov 12, 2009 | 2000 Ford Focus
Model 2305 pump. Housing is cracked. Can I buy
since the pumps cost is only about $40 i doubt that they make after market housings for it and i could not find any
Sep 25, 2009 | Simer 1/6 Hp Submersible Utility Pump
Lower radiator hose leak at water pump housing
water pump housing is cracked ,replace the water pump
Apr 11, 2009 | 2002 Chevrolet Suburban 2500
Simer ACE5S  ACE5S Pump Well 1/2HP Ace 5S Logo
487 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Boyet Soriano
Boyet Soriano
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
