GE AGM24DJ Electronic Room Air Conditioner w/ 23,600/23,150 Cooling BTUs & Electronic Thermostat
Problem for GE AGM24DJ Electronic Room Air Conditioner w/...
No power from the plug at all
By pwrovrload on Jul 08, 2008
I had it on energy saver and last night it just shut off and power would not come back on and the green light for power plug was not lit. I kept it unplugged all day and then when I came home from work I hit the reset button on plug and it came back on and works again. Is this normal?
Solution #1
posted on Jul 09, 2008
Not Rated)
ACTECH
Rank: Guru
Rating: 88%, 62 votes
GLAD TO HERE THAT YOU SOLVED YOUR PROBLEM..
Was this helpful?
Yes
No
Popular Solutions for GE AGM24DJ Electronic Room Air
Questions and Unsolved Problems for GE AGM24DJ Electronic Room Air
Do you recommend GE AGM24DJ Electronic Room Air Conditioner w/ 23,600/23,150 Cooling BTUs & Electronic Thermostat?
Answer
Answer
air worked fine all last night and this morning. Now I cut thermostat on and unit come on for a... (More)
Answer
Have a mistral air con, inside unit comes on but not the main unit outside, is there a fuse in the... (More)
Answer
we installed a msg18 mini split system h/p, tied in tubing, pulled good vacuum , wired 230v. to... (More)
Answer
What does error code E5 mean on my display?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioners Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
