Question about Bosch WFMC 3200 Front Load Washer
How do I replace cold water solenoid on Bosch WFMC 3200 washer...take off top or access from back panel?
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
Take off the top and u will see the solinoid in front of you. just be sure to turn off the power and water b4 replacing.
Posted on Jan 02, 2011
Hot water supply to washer works,but not cold water
Probably the small filter screen in the cold water supply line is plugged up with sediment. The screen will either be directly on where the hose connects to the supply line, or may be on the rear of the washing machine where the cold water supply line connects to the washer, usually a simple screw-on just like a garden hose.
Jun 25, 2014 | Bosch WFMC 3200 Front Load Washer
What would be the reason the cold water is not feeding into the washer
It could be a defective fill valve or the cold water supply could be turned off.
Washer doesn't spin ; model 3200 bosch; 4 yrs. old; other cycles work
Although all brands are different in design, the basic concept is the same. When a machine won't spin, there are several things to consider:
  • Is the belt broken? Loose?
  • Does the lid switch click when closing? (see video below)
  • Does the spin solenoid engage? (1984 and before)
  • Drive coupling worn out? (on some newer Whirlpool & Kenmore top loaders)
  • Clutch worn out?
  • Current to motor? (Use voltmeter to check)
Dec 03, 2009 | Bosch WFMC 3200 Front Load Washer
Put front gasket back on
start on the door side of the appliance put the top of the circle in first this should allow you to stretch the spring a little to make it go on
its a pain and it kills the tips of your fingers try not to overstrech it because it will fall off all the time
Mar 12, 2009 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load will not pump water out
the pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
Dec 18, 2008 | Bosch WFMC 3200 Front Load Washer
E:4 Not draining completely.
open the bottom access panel . 3 screws on bottom
in the center is the large filter access
be ready for some spillage
clean and check the pump impellers for easy turning .
Jun 04, 2008 | Bosch WFMC 3200 Front Load Washer
Water
you need a cold or hot water valve. one of them is not closing all the way after the cycle is done. turn off cold water at wall, if no water appears you know its the cold water valve. if water does apear you know its the hot water valve
Nov 16, 2007 | Bosch WFMC 3200 Front Load Washer
Washer wont drain or spin
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Aug 27, 2007 | Bosch WFMC 3200 Front Load Washer
WFMC 3200 WONT SPIN OR WASH
Open machine's rear panel and look for a broken belt and does the motor spins. Let me know with your results and we will see how could we assist you.
Aug 21, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
132 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
