Question about AOC LM720 (Gray, Silver) 17" LCD Monitor
When I restart computer the screen starts normaly then it goes black. Then the moniter is turned off repeatedly and then it works
So my laptop froze yesterday and I turned it off to restart it. When I restarted it it everything was normal but after the starting windows goes away it usually goes to the login page well now all it does...
Try starting it in safe mode.
When the computer is starting just after the beep or when the bios info goes away press f8 repeatedly and you will get an option to open in regular or safe mode.
Alternativly you can also hold down teh ctrl key and it should do the same.
Did you install or update and drivers recently?
Aug 25, 2011 | Compaq Computers & Internet
In the middle of a session the screen turn black, but the computer seem to be on... we need to stop it with the middle button and restart it again. Usualy it start back normaly again. But one time, instead...
You need to start up in safe mode you do this by pressing F8 while it is booting up you will then see a screen that says start normal or safe mode pick safe mode if it boots up and it will take a little while then shut down the computer by selecting shut down and then restart this will most likley solve your problem
Jan 13, 2011 | Acer Aspire 4520-5582 Notebook
When It goes to loading screen it restarts
It is becasue of your computer is not properly shut down and so your harddisk has some bed indexing of memory location.
For that you need winxp disk or recovery disk.
Then boot your computer with that disk .
You have to set first boot device as your cd or dvd rom.;
For that when you power up press F1 or F2 or "del" key to enter in bios .
Then go to boot option then sewt first boot device as your cd or dvd rom.
then save settings then put winxp or recovery disk in rom.
Then follow the procedure .
Then enter in recovery console then type in prompt "chkdsk /r"
then it fix error on harddisk.
Sometimes this command fix eror and then after restart windows load normally but sometimes need to repair windows.
So after check this if still face issue just chose "r" when it finds your previous version of windows then it recovers your windows.
Let me know if you need more assistanse.
Thanks.
Sep 04, 2009 | Computers & Internet
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Moniter is black
hi sounds like you need to replace the lcd backlight which lights up your cd display when it goes you can still see things but it's very dim if you need help ordering that part let me know and i'll find you the product code hope this helps
Aug 08, 2007 | Balance CN6555 Notebook
AOC LM720 (Gray, Silver) 17" LCD Monitor Logo
13 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
