Question about Saeco Vienna De Luxe Espresso Machine
Can't prime Starbucks Estro Vapore espresso machine
Machine is approx 10 yrs old but hardly used. Have tried priming it by opening the steam valuve while both the steam and brew buttons are in the off position. I am about ready to fling it out the door. Any suggestions??
  • KaffeSumpen May 11, 2010
    What exactly is the problem?
    when you try and prime the machine does it come out water?
    is it failing to add water when brewing?
I can't get that screw off that holds the screen down. I'm trying to change the rubber gasket. The screw just goes round and round in both directions! I'm afraid to just pry it off!
Posted on Jul 18, 2008
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
Gaggia titanium. The water and steam are all going through the brew head instead of coming out the wand when I need it to. I have cleaned everything, used a pin to clean the wand (it didn't need it) ONE...
This is hard to picture. The only way water can come out the brew spout is if the brewing mechanism inside in the position to make coffee. The only way to get that mechanism into that position is to either select one of the three coffee buttons (you'd hear the grinder run, then you'd hear the motor putting the brew mechanism into place and then the pump start and water would then come out the brew spout. OR to select preground coffee and then select one of the three coffee sizes - in that case you wouldn't hear the grinder but you'd still hear the motor turn the brew mechanism into brewing position and then start the pump.
When you simply select hot water and then open the steam valve - I can't imagine any possible way for water to come out the brew spout.
Now if you mean that you don't see any water come out but water is leaking inside the cabinet and ending up in the drip tray - then that would mean a leak inside the machine. It could be the valve that the brew group locks into when it goes into brew position (you see this valve in a little recess behind the brew mechanism when you take the brew group out to clean it). Or it could be a leaking steam valve or hose inside.
You might try getting a flashlight and a cleaning brush - take out the brew mechanism and then clean around that little nozzle/valve that is in the recess just the left of center behind where the brew mechanism was. That valve should shut when you are not in brew position and not allow any water out - but it may be gummed up with coffee grounds.
If you are feeling brave - you would need a deep socket and a lot of patience with a small breaker bar (a ratchet head is too big to fit in there) and you can remove that nozzle/valve and then clean it or replace it. But it is very slow going to remove it (there must be some special tool they use at the factory). I had just the right size deep socket (like what you'd use for a spark plug in a car) but there wasn't room for a ratchet so I had to use a small breaker bar and I could only turn the valve about 1/4 turn at a time then I'd have to reposition the socket to do another 1/4 turn. It took 5-10 minutes to remove it - then it was easy to clean. I think you could clean it in place with a stiff bristle brush and some q-tips.
I don't know if that valve is the problem - but that's the only thing I can think of that would have your hot water and steam running into your drip tray instead of out the steam wand.
Oct 26, 2010 | Gaggia Titanium Espresso Machine
Dishwasher not completing full cycle
Hi i too have the same problem matrix mx194 approx 4 yrs old.On near completion of cycle the 3 center lights out of the 4 on the inside of door flash and a ringing tone indicating a fault. When the door is open there is approx 1'' of water in base of machine and the inside is extremely hot and full of steam.
Can anyone please help
Nov 21, 2009 | Dishwashers
Hi - I have a new Rancilio that I just opened today. Steam is coming but not enough water for a brew
maybe is just air in pump,try prime water on steam steam valve and press button for make espresso,keep couple seconds
Jul 07, 2009 | Rancilio Silvia Espresso Machine
Machine stoppped working
Try this remove the brew unit and clean the screen on the unit, then insert unit, and open steam/hot water valve to prime. If that does not work then there might be a malfunction with the pump, I am assuming that the machine is only 2 weeks old?
Jun 25, 2009 | Saeco Odea Giro Plus Coffee Maker
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Can't Prime Water Circuit
Hi You need to switch Steam ON so it heats up and then turn Steam button OFF (no light) and then turn steamer knob counter clockwise you will hear the pump start up and then water will stream out. This is when it's primed. Turn steamer clock wise to close. You must do this everytime you use the steamer.
Dec 06, 2008 | Saeco VIA Venezia
Flashing brew group light
Brew group light is lighting. Could be a number of things....
Machine may need to be primed. Try turning on the steam valve and let some water threw. See if that helps.
If you can't get the brew drive out, its jammed. You could try unplugging it for about a day, and then plugging it in, sometimes it will reset it self. Else it has to be brought back in, should take 5 minutes to do.
It could also be the descaler light popped on. hold down the steam button and it may turn off.
It could also be a sensor that wasn't put back properly.
Its hard to really say, the light diagnostic system for magic's isn't the best.
May 19, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
484 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
