Question about RTO Atwood Water Heater - 6 Gal LP
Atwood 91043 thermostat. Ploblem is all the time.
  • RTO Master
  • 43,501 Answers
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Posted on Jan 02, 2011
High temp sensor wont reset
Replace thermostat
Copy following link for Atwood service manual and other resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jan 30, 2013 | RTO Atwood Water Heater - 6 Gal LP
Will this solve my problem of the pilot going out after the water is hot?
Your thermo coupler may be going out. If the thermo couple does not sense heat it will shut the gas off. This is a safety feature. Once you replace that you should be ok.
Aug 14, 2012 | Camco 08773 Gas Pilot Assembly 9 Inch for...
I need to know the part number for the thermocouple on an Atwoods mpd 91043 water heater
For a straight, manual ignition, atwood kit #A91603 give's you a new pilot and thermocouple assy. Approx. $30-$35.
Sep 08, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hi i have a atwood 22.7 litre water heater model mpd93754 . IT ignites heats water, but wont shut off when it gets too hot. could you please help solve this problem . many thanks rod baker.
Gas control valve thermostat might be bad.
The copper cylinder located on back of gas control that sticks into water is the thermostat.
If thermostat is not reading correct temperature, then gas might stay lit.
Usually the gas control will sense overheated water and trip the ECO so no gas will flow to burner.
In any case, the gas control valve is replaced.
http://www.adventurerv.net/images/91601.jpg
Open following links to see typical manuals, service manual, parts link, and other resources:
Jul 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
Hi, I have a Atwood 91043 (Model 37C14U-5). The pilot and main burner seem to work fine (main burner ran a couple minutes then shut down) but I'm not getting hot water at the facet. I have the...
Have you checked back of water heater for proper valve positioning? (by-pass may be on)
Cold water enters through bottom fitting and hot comes out the top. Any valves in between should be closed and any valves going in bottom and out top should be open.
Jun 03, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Have a atwood m#91043 hot water heater.pilot will not stay light.Have changed temocouple.Still the same problem.
If you've replaced thermocouple with new proper one, and you have a good blue flame under it when pilot held on. Try removing the thermocouple where it connects to gas control and spray WD-40 or similar in the hole where the thermocouple was removed from, and take some steel wool (fine) and twist a piece of it small enough to fit in the hole and get to bottom where contact surface is and spin it to clean the contact surface well. Clean it out after with compressed air if possible, then re-install thermocouple and snug it up good and retry it. If that doesn't do it, your going to have to replace the gas control valve.
Mar 03, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a Atwood dsi water heater that after hot it wil keep lighting run a few minute and shut off and it will keep doing this but some times off for hours normal. I changed thermostats no difference
Don't forget pressure relief valve as well. Small drip is acceptable though. Double check by-pass valves are in proper position as well.
Thermostat if working properly would have to sense (feel) cooler water at it's location in order to re-ignite system, which makes me think, cooler water is circulating through there somehow.
Dec 14, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have atwood GC6aa-9e, will not fire the ignition tries 3 sets
Have you tried temporarily removing the thermal cut-out from the circuit to see if ignites then? It's the little resistor looking thing inside the plastic sleeve/cover that runs to thermostat. Disconnect it from the thermostat terminal, and from wire that is on the other end, and you should be left with a female spade connector at end of that wire. Connect that directly to thermostat terminal where the other part was connected, and try it. If it works, the thermal cut out is no good and needs to be replaced for safety reasons, in case of flame out of control, it blows and shuts gas valve off.
Jun 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a atwood hot water heater GC6AA-10E its o...
Does yours have the little cut-out diode looking thing in the plastic jacket installed between power wire and thermostat? If yes, remove it from the circuit and connect female spade of wire, to male spade of thermostat,(just removing it to by-pass it) and try it now. Let me know what happens.
May 20, 2010 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood Water Heater - 6 Gal LP Logo
354 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
