Question about Jenn-Air JES9860 Electric Kitchen Range
1980's Jenn-Air Electric Range. We closed the lock for "Clean" and when it was done, the latch won't release. What can we do to get it to open again?
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
jsrock516
  • 5911 Answers
SOURCE: Electric Range Door Locked after cleaning
"F1" is an error code for any of the following possible problems: Electronic Oven Control (EOC) board. Wiring harness shorted. Defective touchpad on the control board. I speculate that the control board may have failed during the cleaning cycle, causing your problem. Unfortunately, this may be an expensive repair if it is a control board, and it could be maintenance intensive to get to the door latch to release it. You will need to lift the stove top to gain access to the linkage for the oven door relay. There should be a few screws under the top front to remove. Make sure you unplug the unit or turn off the circuit breaker before servicing. I hope this helps you.
Posted on Jul 28, 2007
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
  • 16 Answers
SOURCE: Oven won't lock and self clean.
Shut off the oven for at least a minute and turn it on, set the clock, and it worked. I had tried a short power cycle before and it didn't fix it. The extended power cycle did the trick.
Posted on May 02, 2008
SOURCE: Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Posted on Jun 13, 2009
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
Cannot start self-cleaning 20 year old insert oven
door need to lock before it can clean so check for obstructions in latch or find out why its not locking
Jan 27, 2010 | Jenn-Air JES9750 Electric Kitchen Range
How to turn off self clean oven Jenn air slide in older model after it is done cleaning
the self clean cycle will run for 2-3 hrs and the door will remain locked for another couple hrs while cooling let it finish and wait till the next day basically if it still wont open (sorta common) the door lock assy needs replacing.
Oct 08, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Locked oven latch
It is just a guess on my part, go to the electrical panel and turn the breaker for the oven off. This should release the lock if is an electronic lock. If it is mechanical, I guess it is back to the drawing board.
Aug 30, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Mar 19, 2009 | Jenn-Air JES9860 Electric Kitchen Range
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Mar 14, 2008 | Kitchen Ranges
Jenn air s136 stove won,t self clean
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jul 28, 2007 | Jenn-Air JER8850 Electric Kitchen Range
Jenn-Air JES9860 Electric Kitchen Range Logo
281 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
