Question about Lasko Ceramic Heater
My Lasko 5805 heater worked fine and still works fine except the temperature shown is now in celius instead of farinheight
  • 312 Answers
Hi, I looked through the manual for the information to change the thermostat display from reading Celsius to Fahrenheit. Couldn't find anything. I did find a number to call for customer service
800-233-0268
Also, Here is the link to the manual.
http://www.laskoproducts.com/instructions/5800Ins5800ESa.pdf
Hope this Helps,
Happy New Year,
Mark
Posted on Jan 02, 2011
The on/off switch no longer works
check the bottom of heater for a push button type switch that is supposed to sense that the unit is upright ...also try it on a solid flat surface
Jan 18, 2014 | Lasko Heating & Cooling
Schematic plf504d thermalinc
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Dec 13, 2013 | Lasko 5610 Baseboard Heater
How do i prevent my lasko heater to keep raising the temperature? i can't seem to set it to stay on one!
If its a central heating unit you should make sure the batteries in the thermostat are good and the fan switch is on auto. then you can open the cover to the heater and tap on the relay. that will usually shut it off if its just sticking. It could be a black box by itself or a box on the circuit board depending on the model
Nov 29, 2012 | Lasko Heating & Cooling
I have model 5805 and i seems to always run, never shuts off and doesn't get my childrens small room warm (10x10) thought room wasn't holding heat so i put my lasko tower heater in there and it worked just...
Sounds like the ceramic heater has lost it's ability to heat completely. In other words, it doesn't peak any more.
Can it be repaired? Possibly, but finding the part(s) may prove difficult. However, if you can safely disassemble the heater, I would recommend that you try cleaning the interior with a can of compressed air that has a straw nozzle (like you clean your computer with). It may simply be a case that it's clogged with dust and lint. Try not to disturb any of the electrical parts when you do this.
Hope this helps solve your problem.
Feb 28, 2011 | Lasko (7564) Heater
I just purchased a lasko model 5805 ceramic heater. What's the cost to operate.
look for the power rating of your heater (usually it is in Watts (W) and convert it to kilo Watts (kW) unit by diving it by 1000).
kW = W / 1000.
now divide the kW by hour many hours your planning to operate your unit.
power consumption = kW/operating hours
when you get your power consumption value then multiply it with the power cost (you can find it usually in your bill).
cost to operate = power consumption x power cost.
Happy New YEAR!!!!
don't forget to rate me...
Dec 31, 2010 | Lasko Ceramic Heater
Our Lasko 5620 has a digital control, but we can't set the temperature. It says at 76 degrees, no matter what we do. Hitting the control buttons does not work.
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Jan 10, 2010 | Lasko 5610 Baseboard Heater
Heater won't get hot
I went on several websites until I located the company. Recieved a call from them to day and they are sendin me a manual.
Dec 15, 2008 | Lasko 5520 Ceramic Compact Heater
Won't shut off when reaching preset temp
The heater shuts off when it reaches two degrees above the set temperature and turns back on when it is two degrees below.
Dec 13, 2007 | Lasko 5365 Ceramic Compact Heater
Lasko  Ceramic Heater Logo
508 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
