Question about Able Planet NC1000 Headphones
I hear a static when the headphones are plugged with no sound playing. The static seems to come intermittently and alternates between the left and right ear.
Nearly constant static
Your cable or phone jack connection is defective.
Mar 12, 2014 | Sony Mdr7506 Professional Large Diaphragm...
I can only hear static through the headphones on my Fostex MR16. The recording sounds fine when I transfer to computer, but I can't hear myself playing.
They make headphone amps that will take a line level and boost it in volume until it can drive headphones. I'd get one of those, and plug it into any available "line out" or "rec out" on the back of your Fostex. Sounds like the D/A converter section that feeds the headphone output has gone bad, and my solution will get you around that.
Nov 27, 2013 | Fostex Mr16hd 16 Track Digital Recorder
Rear Entertainment Systems plays sound on right side only
Using the wiring colors check the head unit output with a test speaker.
Apr 13, 2017 | Audiovox Car Audio & Video
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
My headphones have stopped working. the plug attached to the left headphone seems to have disconnected as when i wriggle it sound comes through intermittently
there is nothing you can do but open the casing and cut the wire as close to the solder as possible then solder it on again then they will be like new again its a really easy job
Jan 31, 2011 | Bose On-Ear Headphones
Brookstone wireless headphones have static along w/ tv sound
Well I just plugged into the cable box and that worked. On my old tv as well as my newer one the only audio out was an optical I had bought an optical splitter (one input for my sound bar and the other one to the optical to Rca) and an optical to rca for the headphones. This allowed me to use the headphones on all things going through the tv. For some strange reason it no longer works that way (just got my new tv this week). I bought all pieces on Amazon for a nominal cost. I'm going to doublecheck all connections again tomorrow.
Jul 12, 2010 | Brookstone Surround Sound Earbuds...
When i plug my headphone in all i hear is statics from it and nothing else and i need to know wat is wrong
Do you still hear static on the external speakers? I mean if you remove your headphones? If yes, it is a sound card issue and you could try to re install the drivers to fix it. If no, it could be your headphones.
Hope this helps.
Oct 03, 2009 | Gateway M675 Laptop
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Turtle Beach X1's(xbox360) Not working as they should be?
Check and see if your TV is on a mono setting. That would cause all sounds to play through the right and left speakers or the headphones.
Mar 07, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Can't hears sounds without headphones
i guess u have 2 replace your speakers visit a nokia gallery
Nov 04, 2007 | Nokia 5300 Grey Cellular Phone
Able Planet NC1000 Headphones Logo
Top Able Planet Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Able Planet Audio Player and Recorder Expert? Answer questions, earn points and help others
