Question about Dell P1500 Laser Printer
I replaced the toner cartridge on my printer but i am still getting black dots/small smears on printouts. Any idea what I can/should do?
  • 125 Answers
Even if you replace the cartridge a hundred timesdots will not gone. Solution: take out the drum unit then examine the opc drum by turning manually there you can see a piece of gum attached, then remove it gently by using a wet cotton, then problem gone
Posted on Jan 02, 2011
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
I have a problem with the colour prints...there are different kind of lines all over the page..how can i clean the laser heads?is there any automatically way?
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Try cleaning the toners and see if it makes any difference. You would also have an idea about the toner drum/ parts quality etc and check if they need to be replaced. Furthermore, issues with Laser Unit like dust/ toner dust on the lenses and mirrors inside the printer usually result in faded or discolored prints. For instance, faded text/ picture at certain areas or any color missing when you print.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
I have just collected a second hand HP 1600 printer and there is a 2cm green vertical line down the left side of the page and a 3mm line down the centre and 2 thin lines down the right side, help!
Also, make sure that the visible inside of the printer and the Black belt are clean and there is no spilled toner inside, which sometimes results in dots.
CreativeTECH
Jun 16, 2011 | HP LaserJet 1600 Printer
There are black smears on the edges and some dots on the papers
How much toner is left in the cartridge? Some models will bleed a little when the toner get low.
Mar 22, 2011 | Brother HL-4040CN Laser Printer
Printed pages are smeared with black
Sounds like a bad toner, or possibly the scanner is dirty. If you look where it pulls the paper through it can have a small speck, but since its on the scanner tself it will put black lines all the way down the paper.
If its larger and smeared the Toner itself is probably bad and you need a new Toner Kit, should come with new rollers and a new cartridge as well.
Mar 01, 2011 | Dell 5110cn Laser Printer
Printer: HP Laserjet 1010 model Black dots appear on the paper
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 10, 2010 | HP LaserJet 1010 Printer
Replaced toner cartridge and now get printout of
try to reinstall the printer driver. then align the printer toners. then perform some test print.
Mar 08, 2010 | GCC Technologies Elite 12/600 Laser...
The printer is printing little black dots on my documents
If the dots are all over the paper you may need to replace your toner cartridge. If the dots are smearing, you may need to check your fuser assembly (have it checked by a professional).
Oct 06, 2009 | HP LaserJet 1012 Printer
Black dots on printout
This is not a solution, but if it is any help, I have just started having the same problem. The dots are about 1mm diameter, exactly 75mm apart and 30mm from the right hand edge of the page. I recently refilled the black cartridge with toner and reset the mechanical device that registers the cartridge as empty.The problem is unlikely to be the cartridge, however, since that does not determine where toner is deposited.
Mar 31, 2009 | Brother HL4040CN Laser Printer
Hey m8
  • Buxie, first off you have voided your warrenty, secondly
  • If marks repeatedly appear on the printed side of the
    page at even intervals:
    • Clean the inside of the printer. See “Cleaning the
    Inside of the Printer” on page 5.7. After cleaning
    the inside of the printer, if you still have the same
    problems, install a new toner cartridge of the
    problem color. See “Replacing Toner Cartridges” on
    page 5.3.
    • Parts of the printer may have toner on them. If the
    defects occur on the back of the page, the problem
    will likely correct itself after a few more pages.
    • The fusing assembly may be damaged. Contact a
    service representative.
  • If horizontally aligned color or black streaks or
    smears appear:
    • A toner cartridge may be installed improperly.
    Remove the toner cartridge and reinsert.
    • A toner cartridge may be defective. Install a new
    toner cartridge.
    • If the problem persists, the printer may require
    repair. Contact a service representative.
  • SXPRESS- It is normal to have to replace it after that because the starter cartridges are rated for 1500 pages but that is at only 5% page coverage and most people print alot higher coverage than that, and the replacements cover 2000 pages again @ 5% page Coverage
May 20, 2008 | Samsung CLP 300 Laser Printer
Dell P1500 Laser Printer Logo
74 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
