Question about Moyer Diebel 24 in. 301HT-40 Built-in Dishwasher
What is the hlts booster, and how do I turn down the temperature ?
    Problem Solver:
  • 40 Answers
Hlts is a high limit thermostat and usually can be reset. To turn down the temperature usually involves adjusting another thermostat with a control knob.
Posted on Feb 14, 2014
Hobart LXIH !The booster is not getting to temperature!
Follow the wires for the contactor coil one of them is connected to a resetable hi limit, press the button on the hi limit to reset
Feb 29, 2016 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Step by step instructions for replacing brake booster on a 1999 Toyota Camry
its my pleasure to answer your question how to replace the brake booster :
1 With the engine off, step on the brake pedal several times to relieve the brake booster of vacuum.
2 Press the brake pedal down and start the engine. Verify that the brake pedal sinks slightly. Turn off engine.
3 Remove the vacuum hose from the brake booster.
4 Remove the brake lines from the master cylinder. Remove the master cylinder from the brake booster. Plug the fittings to prevent brake fluid seepage.
5 Disconnect the brake pedal from the push rod.
6 Have an assistant hold the brake booster from inside the engine compartment. Remove the nuts that hold the brake booster to the firewall. These nuts are usually located under the dash on the interior of the firewall.
7 Remove the brake booster.
8 Install the new brake booster to the firewall. Tighten the mounting nuts.
9 Connect the push rod to the brake pedal.
10 Connect the vacuum hose to the brake booster.
11 Attach the master cylinder to the new brake booster and reconnect the brake lines.
.12 Bleed the brakes at the master cylinder.
Oct 04, 2013 | Cars & Trucks
How to remove brake booster on 1999 Toyota Camry
The following steps will help you to replace a Toyota Camry brake booster :
Temperature on compass/temperature /trip computer is incorrect showing 85 when temp in high 90's
CHECK FOR A DEFECTIVE POWER BRAKE BOOSTER, THE BOOSTER OPERATES WITH ENGINE VACUUM. THE EASIEST WAY TO FIGURE OUT IS TO LISTEN FOR A HISSING SOUND WHILE DEPRESSING BRAKE PEDAL, ALSO IF YOUR TRUCK HAS A R.P.M. GAUGE (TACHOMETER) LOOK FOR FLUCTUATION ON GAUGE. THA BOOSTER HAS A MAJOR VACUUM HOSE ATTACH TO ENGINE INTAKE MANIFOLD FOLLOW HOSE TO INTAKE DISCONNECT AND TURN ENGINE ON TO SEE IF THE INTAKE PORT IS FREE OF RESTRICTIONS. SOMETIMES THEY WILL GET CLOGGED WITH CARBON.. IF INTAKE PORT IS FREE THEN CHECK FOR PROPER VACUUM WITH A VACUUM GAUGE, READINGS SHOULD BE FROM 15-18 INCHES OF VACUUM. GOOD LUCK RE-POST IF NEED MORE HELP.
Aug 27, 2011 | 2000 Jeep Grand Cherokee
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Overload was tripped on the booster tank?
thats ok, just reset, if it happens again replace. could be that the booster thermostat didnt shut off the one time. Keep an eye on the temperature guage to see that the temperature is not fluctuating too much over 85c
May 06, 2010 | Moyer Diebel 401HT Dishwasher
What does error code 205 mean on the Meiko FV40.2
This error code means your booster heater is not getting up to the proper temperature. You can check your amp draw across your booster heating element to verify it is in fact heating and not blown. Also, check your temp sensor for resistance. At room temperature, you should read about 1000 Ohms. At 180 degrees, you will read about 1500 Ohms.
Mar 15, 2010 | Meiko FV 40.2 Dishwasher
Err Code 210
What you need to do is check the resistance of the booster tank temperature probe. The error 210 means a short circuit in the booster temp probe. At room temperature, the resistence should read about 1k Ohms. If you are reading significantly lower than that, then you will need to replace your booster temperature sensor. You also want to check the 4 pin square molex connector on the I/O board on top. Make sure all connections are tight, secure, and that there are no "bridges" across the connections for the temp sensors.
Feb 19, 2009 | Meiko FV 40.2 Dishwasher
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Moyer Diebel 24 in. 301HT-40 Built-in Dishwasher Logo
75 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
