HOW DO YOU RE-INSTALL PRESSER PLATE ON A SINGER MODEL 4411 WHICH SIDE DOES THE LITTLE TAB GO INTO...
LEFT OR RIGHT AND DO YOU PUSH LITTLE SLIDE TO INSERT?
HELP I CAN' T FIGURE IT OUT...
The Singer 4411 has a hidden switch to raise and lower the feed dogs. It's on the back of the machine near the presser foot. You have to remove (slide to the left, from the front of the machine) the extension table/accessory box to access the switch. Move the switch away from the body of the machine to raise the presser foot. See page 24 of the manual for the picture.
Here are the steps to open the bobbin compartment on a Singer 4411 sewing machine:
Turn off the sewing machine and unplug it from the power outlet.
Locate the bobbin compartment on the front side of the machine, below the needle plate.
Hold the handwheel on the right side of the machine with your right hand and turn it towards you (counterclockwise) until the needle is at its highest position.
Slide the bobbin cover release button, located to the right of the bobbin compartment, to the right and hold it there.
The bobbin cover should now pop open. Gently pull it towards you to fully open the compartment.
To close the bobbin compartment, simply push the bobbin cover back into place until it clicks and locks into position.
Unlikely you will get a manual but here are the instructions. Presser foot up, thread the top of the machine as normal all the way and through the needle, open slide plate, push the little button to the side and the winder will raise, take the thread from the needle and wind it round a few times round the screw that holds the presser foot on, gently press on the foot control and the needle will go up and down winding the bobbin, when you have enough thread on the bobbin close the slide plate and you will hear the winder drop down, pull the thread to the back of the machine and you are ready to sew
on touch and sew models thread the machine up as normal, select straight stitch, presser foot up, take the thread from the needle and wind it round the presser foot screw a few times, open the slide plate, push the little button over, press gently on the foot control to wind the bobbin, when finished close the slide plate to drop the winder down and pull the threads to the back and start sewing
Take your thread that is under the presser foot and wind the thread on the tension disk. It is located right above and to the left of the presser foot. Then you will drop in the bobbin and slide the thread into the **** in the top of the bobbin. Push the little white tab in the bobbin slot all the way to the right until it is in the center of the bobbin. Then press the foot feed and the bobbin should wind.
To wind the bobbin, select straight stitch, thread the machine up as normal making sure the presser foot is up, open the slide plate, push the little button over to raise the winder, take the thread and wind it round the presser foot screw a few times, press on the foot control slowly and the bobbin will wind, when you have enough, stop, close the slide plate to drop the winder down, pull the threads to the back and start sewing. for manuals try www.tandtrepair.com
To thread the bobbin, open the slide plate, make sure the machine is threaded all the way up as normal, take the thread and wind it round a few times round the presser foot screw, push the little lever over near the bobbin to raise the winder, slowly press on the foot control and it will wind the bobbin, when you have enough thread, close the slide plate and draw the thread to the back of the machine and start sewing.
thread the machine up as normal, presser foot up,open the slide plate, push the button over to raise the winder, take the thread from the needle and wind it round a few times round the screw on the presser foot, press gently on the foot control and wind the bobbin, when you have enough thread close the slide plate and draw the threads to the back of the machine and away you go.
slide open metal plate, there is a little white finger button with a target symbol on it just to the left. Slide this all the way left, leaving plate OPEN. If your top needle is threaded correctly, you should now be able to push the foot pedal to sew adn the bobbin will refill. make sure not to go past the outer white line on the bobbin case. good luck. the target button will go back to the original position when you slide the plate closed.
