Question about General Electric Water Heaters
Water gets cold after 3 min.s - General Electric Water Heaters
1) You have to give more information to get accurate answer about water heaters.
Is this a gas or electric water heater.
What type of heater: tankless or tank or hybrid or power vent or indirect boiler or instantaneous under-sink or RV heater?
What symptoms have you noticed prior to now? Less hot water than usual?
Have you installed new gas appliance that might affect gas water heater?
Did you paint floor with urethane and gas heater suddenly stopped working?
Is the circuit breaker tripped on electric heater?
With electric heater, did you open top panel and push in reset button?
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
How old is the water heater? What brand do you have and what does label show on side of tank?
Is the water heater also leaking, or is it in good condition?
Add a comment.
2) If you don't want to add a comment for further free help, then take advantage of fixya phone service. For a price, fixya expert will ask you same questions and more questions via phone, and then possibly help you resolve issue.
3) If you don't want do-it-yourself help from fixya, call a plumber and give plumber as much information as possible, and plumber will fix heater or install another one. The more knowledgeable and helpful, the more the plumber will try to help you.
4) Double-check any information you receive from fixya and from professional plumber by posting question on professional plumber's forum like the Tank: http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Jan 02, 2011
My hot water to the shower goes cold after 3-4 mins could please help?
a couple of things to check on the side of the hot water system you will see a valve with a small lever
lift that lever until there is a solid stream of water coming from the pipe
that ensures that the heater tank is full
next -if you have a temperature mixer on the hot water pipe out of the tank ( stops scolds in the bath, shower sink) by controlling the temperature mix at the tank
They are known to fail and shut down the hot water supply by adding extra cold water into the system
other than that get a plumber in to fix the fault.
Apr 20, 2015 | Water Water Heaters
I keep getting a code 13 and no hot water after about 3 min. Vent is clear??
Undersized gas line?
Temperature set too high?
Haven't kept up with regular maintenance?
Tankless older than 5 years?
Hard water over 7 grains?
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
Sep 17, 2014 | Rheem Richmond Encore Tankless LP Gas...
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
Low pressure coming from Hot Water Tap
Were is the water boiler located.
Feb 20, 2014 | Water Heaters
Hot Water Pressure from taps
Hard water deposits from the water heater in the supply lines to the faucets. Sounds like your water heater needs to be cleaned out -- not just drained of water. You need to get inside and clear out the deposits in the bottom of the tank. You also need to remove the hot water supply lines to your faucets and see of you can get the lines to run free from the deposits -AFTER you clean out the water heater. Remove the drain -put on a 3/4 in. ball valve for the drain and a hose bibb on that - you can hook up a 5/8 - or 3/4 inch hose to get the particles out of the drain of the water tank. You may have to blow back the water line, from the faucets, the hot water lines- to get the deposits out of the water lines. You also may have to blow out the faucets with the water line disconnected to clear the calcium out of the hot side of the faucet.
Feb 18, 2014 | Water Heaters
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater. Problems with constant hot water. The heater turns ok but (i think) when i turn on the cold side the heater stops. at...
Possible flow sensor issue. Check to see if your water pressure fluctuates a lot or is fairly steady. These units are sensitive to the pressure. take care.
Feb 19, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Rinnai XR 20 - water temperature varies hot - cold - hot etc during 4 to 5 min shower
your gas supply may be to low to keep the unit firing while you are showering...especially if you have other gas appliances running while you are using the unit.
If this is happening after someone else has recently used the unit....then it may be a problem that some call stacking. The unit works on flow....not sure about that unit but they usually take between 1/2 - 3/4 gallon to turn the burner on. If someone recently used it and then you get in the shower...you will get the hot that is already in the line but then it takes that initial amount to fire again, thus loading the pipe with cold water.....it then comes out on you followed by the hot that has finally entered the line. Once it is past that point there should be no issue, unless it it a gas problem like I mentioned.
Oct 24, 2009 | Rinnai Water Heaters
Heater stops heating water
you have to much volume of water going thru the unit, did you size it properly by haow many baths and showers you have or did you just by the cheapest one,, there is a scale to go by run just one shower and see if it changes temp, with nothing else running,, a shower has 2.5 to 4.5 gal per min,, then you can also check to make sure it has the right size gas line 3/4 from the meter to the unit is required at a min of 2lbs of gas
Jun 17, 2009 | Rheem Tankless Hot Water Heater...
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
Hot and cold water from tankless heater
check your tigh/low water temperture setting. you may have them crossed.
check all of your wiring.
Jan 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Water Heaters Logo
108 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
