Question about Cobra 25 WX-NW-ST 40-Channels Base CB Radio
I need to know what size the resister is on the power supply
  • AnyMHz.com
    AnyMHz.com Sep 26, 2011
    Can you explain more.. of what your doing?
    Novelist:
  • Cobra Expert
  • 500 Answers
If your meaning a fuse its a 2amp min-5amp max...
Posted on Jan 03, 2011
HOW TO REPLACE AN AC CAPACITOR
1- Turn all power off to unit
2- Discharge capacitor by touching both/all terminals together with shock resistant pliers/tool.
3- Removed capacitor and find info on size. Mfd rating/uF
4- HVAC supply house will match capacitor, or you will have to order it.
5- Replace using same wiring/terminals
6- Turn all power back on
7- Check operations.
Sep 02, 2014 | Heating & Cooling
Tip
Air compressor will not start
An electric air compressor motor may start up fine on an empty tank but not when the tank has air in it. Additional torque and power is required to start when not empty. The electric wires may be too small or their length too long and represent electric resistance in the circuit. Larger gage wire will have less resistance and provide more power at motor start up under load.
A motor uses 6 times the amps when starting, a normall size and length wire is capable to deliver this power momentarily. The problem is when the wire is lengthened without using a larger gage wire. Resistance consumes power and the wire resistance will consume power causing a voltage drop to the motor. A motor, as most electric loads needs plus or minus 10% of its rated voltage to operate. What I'm saying is that a larger gage wire must be used, 1 gauge size to 25 feet, 2 gage sizes to 50 feet, or more size larger when using extension chords depending on length. I keep some romex of heavy gage with chord ends on it to use as temporaty long extension chord for compressor or welder use.
on Feb 12, 2015 | Air Tools & Compressors
What determines the size of a backup power supply neeed?
Check what it says on the back of your computer and monitor.
Add together the effects of the smallest size you need ...
Note that a laser printer should never be connected to a UPS!
Aug 26, 2014 | Computers & Internet
Connex 4600 turbo need too know what size power supply I need too run this as a base
sizing a power supply is simple.....look at the fuse in the radio, and add about 40-50% to it, and look for that size psu
Feb 15, 2014 | Radio Communications
The power button light on my dell pc is
You can install the power supply from another computer provided the wattage is equal to or greater than the original one.
The only problem you may have is the physical size og the power supply. The desktop computer power supply is usually larger in size to the smaller compact computers. You won't know until you remove the power supplies from both computers. You can also purchase power supplies from computer repair shops or on the Internet.
Jan 30, 2012 | Dell Computers & Internet
What is the correct amps for the 12 volt transformer
the current measured in ampere which depends upon the resistance . V/R=I{ohm's law} . as resistance is low , current becomes high . power supply gives that much current which circuit takes no fixed current transformer gives whatever current mentioned on the transformer .i.e., maximum current capacity of that transformer .
Apr 20, 2010 | Computers & Internet
Fuse
same size fuse as car has
Jun 18, 2009 | Aerocool AEROPOWER II SL450...
Regulated dc power supply
If it is fused at 10 amps, then any power supply 8 amps or greater should be adequate.
Nov 08, 2007 | GE 35840GC3 2-Way Radio
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
Cobra 25 WX-NW-ST 40-Channels Base CB Radio Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
