Question about Kenmore 62722 Electric Dryer
Dryer gets hot. Won't spin. - Kenmore 62722 Electric Dryer
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you have a broken belt, if your unit is not blowing hot air, you then have a defective motor.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Kenmore stack top loading washer and dryer
kenmore washer won spin YouTube
Kenmore is sold by sears so go to
http://www.searspartsdirect.com/
Enter your model number to get user manual, parts diagrams parts lists and order parts.
Model numbers are usually covered by the lid or door.
Oct 01, 2014 | Washing Machines
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Samsung DV338aew does not get hot
I just took the front panel off of my Samsung dryer the belt is off. If you take the front panel off you won't believe what you will see it's so much dust... from all the clothes drying. Did you tried to take the front panel off? First turn off the switch to the dryer at the fuse box so there will be no power in there while you vacuum it out. As soon as I can put the belt on I will vacuum it thoroughly. I'm sure that is the reason why it the temp... is not hot enough.
Good luck.
Erika
Aug 12, 2012 | Samsung DV218AEW Electric Dryer
Dryer spins but won't get hot. Bad heating element? If so , where is it located?
Check your circuit breaker. It may not be your dryer at all. 220 dryers run on two separate circuits one to run the motor the other to run heating element.
Sep 03, 2011 | Maytag SDE4606A Electric Dryer
Hello, I have just purchased a frigidaire gallery series stackable combo 2004 model glet1142cso after hooking it up i am having problems. It won't fill unless dryer door is open..won't spin out...
Probably an auto tec installed the recepticle on the wall or in the electric pannel. in home electric the black wire and the red wires are hot. In automobiles the black is ground. You should have 240 volts between the two flat connectors on the plug when its pluged into the recepticle.
Dec 20, 2017 | Frigidaire FEX831F Top Load Stacked Washer...
My dryer does spins and turns on, giving minimal of hot air. Knob usually turns as the load is almost done. knob is now not turning at very hot mark on perm press cycle. Vents are clear.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 24, 2010 | Maytag PYE2300AY Electric Dryer
Dryer does not get hot
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 10, 2010 | Magic Chef CYG2000AWW Gas Dryer
Dryer gets hot spins takes several cycles to dry fully
ahhh very common, clean clean clean inside the dryer, take the lint screen put some toliet bowl cleaner on it let it sit while you are tearing the dryer apart and clean the whole dryer vent and or change it, make sure the flap outside is not stuck shut as well...
May 08, 2009 | Dryers
Maytag dryer problem
sounds like the motor. if the motor gets too hot then the overload on the motor wont let it come back on until it cools off
Nov 25, 2007 | Dryers
Kenmore 62722 Electric Dryer Logo
134 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
