Question about Bernina Bernette 75
How can i open the top of a bernina 730 record, the top is tight and wont pop open like it is meant to?! please help
  • 8 Answers
SOURCE: Bernina 730 Can't open top cover !
The problem is that of a stuck piston detent on the pattern selector support that snaps the top cover closed.
  1. Open the light cover
  2. Apply pressure with thumbs on the bottom edge of the top cover on both the right and left sides of the cover. The cover should pop up...Too much pressure on the left side, (if this thing is really stuck) and you might break the top cover at the thread tension slot. Be careful here....
  3. Add a drop of acetone (fingernail polish remover) to the piston detent and work it free by pushing it back and forth. Avoid getting any acetone on the painted surfaces of the machine.
  4. Continue to work free, repeating with a few drops of acetone, and wipe clean. Don't oil this part. It was a petroleum product combined with a galvanic process (aluminum and steel) that caused the problem in the first place, not to mention age.
  5. Use DTE Heavy Medium oil rather than a white or clear oil when you lubricate your machine. White oils are unstable and will oxidize (decay) much more quickly. Also avoid 3 in 1 oil and stuff like WD40....very bad....
  6. Oil 1/2 a drop on those prescribed areas. Too much oil is more harmful than not enough....
  7. Contact your Bernina dealer for this oil.
Posted on Sep 06, 2009
Testimonial: "To swiss_tech Great help. Very much appreciated. Thank You"
SOURCE: My Bernina 730 record can only run the zig-zag
Sewing machines needs full service now and then (every 10 years will often do). The motor on the 730 series is actually as powerful as they get on domestic machines, and handles just about everything that fits under the pressure foot. Only if the machine has been used a lot over the years are the brushes worn down, but it might need new grease not matter how little it has been used.
However, the stitch applications can sort of gum or clog up if the machine has not been used for ages. Take a look in the manual and oil ever point suggested every time you take out the machine. Try them now and then on slow speed, that might get every function to run smoothly again.
This is as good a machine as any out there, favorably compared to any new machine under 500£. It sews perfect stitches on just about any material, and is well worth a full professional service (At a shop they will always recommend a new machine they want to sell you). All kinds of pressure feet and accessories are available in regular sewing shops and online.
Check with different shops for price on full service. This is a great machine what ever they tell you.
Posted on Jan 09, 2010
  • 1116 Answers
SOURCE: need bernina sewing machine model 730 manual
Here is a download - http://www.berninausa.com/webautor-data/486/BERNINA_730_731_732_manual.pdf
Posted on Mar 14, 2010
  • 22 Answers
SOURCE: I need to replace a camstack on a a Bernina Record
I would suggest taking it in to a dealer, how ever if you are up to it i can provide you with step by step on how to start and finish this job
Posted on May 03, 2010
Zenqi
  • 208 Answers
SOURCE: How do I change the light bulb of my Bernina
Push up on the bulb and turn counter-clockwise and the bulb will come out.
Posted on Jul 29, 2011
I have a bernina 730 and it does a fabulous straight stitch but it won't do zig zag or any ornamental stitches
Assuming this is the older mechanical Bernina 730 Record (not the new computerized model)...Sounds like your machine is seized due to dried oil.
Wheel on right side that controls the needle up and down is very tight...
Jan 09, 2017 | Bernina Sewing Machines
Stitch selector knob on bernina 600, not Deco, is stuck and cannot select needle position, However the width of stitch part of the knob is working.This knob has 2 parts, needle position and width control
Your machine (Bernina 600 Record) has most likely frozen (seized) due to lack of regular maintenance. Don't panic. It can be fixed with a lot of elbow grease, good quality oil and a hairdryer. The following method has resurrected several Berninas I've picked up as "nonworking."
How can fix stuck needle bar on my Bernina 730
It was working now it seems to be frozen the needle part wont move
Nov 01, 2016 | Bernina Sewing Machines
Bernina 730 how do I change feed dog pressure it is way to high not touching fabric when down??? Help please
There are actually two Bernina 730 machines (confusing, huh?). One is the 730 Record from around 1960. The other is the more modern 730 computerized model made in the 21st century.
The 730 Record has a hidden pressure adjustment. Lift the top cover and locate the screwhead on the very left side (left of the takeup lever knuckles). This screw loosens or tightens the spring that applies pressure on the presser foot.
The manual can be downloaded here, although it does not show the pressure adjustment:
BERNINA Sewing Systems
On the computerized 730, the pressure adjustment is on the screen (pg 37 of the manual):
Jun 25, 2016 | Bernina Sewing Machines
Bernina 730 Record Service manual
Service manuals are difficult to find for most sewing machines, which Bernina is not an exception. However, there is a Yahoo Group called "BerninaThirtySomethings" that has conversations, documents, photos, etc. for the vintage Berninas including the 730 Record. You can join the group (must have a Yahoo email account) and download a variety of documents including a "Setting Manual" for the 730.
Yahoo Groups
http://www.thesewingforum.co.uk/showthread.php?t=28999
Apr 15, 2016 | Bernina Sewing Machines
How do I keep the walking foot from unscrewing the needle holder on my bernina record 730
Tighten your needle with a screwdriver, instead of finger tight. If that continues to happen, take your walking foot back. That is not normal, and could end up injuring you or damaging your machine. Good luck!
May 24, 2014 | Sewing Machines
Bernina 730
try changing the needle--one for the fabric being sewed
also the zig zag could have a worn or damaged gear or cam
or there could be a timing problem.
Apr 11, 2014 | Sewing Machines
Bernina Record 730 hand wheel stuck
OK OBRIGADO VOU LIMPAR A MAQUINA PODE SER POEIRA PORQUE FICOU ALGUNS MESES SEM FUNCIONAR.
aGRADECIA SE ELA FUNCIONASSE TENHO MUITOS TRABALHOS POR FAZER SOMENTE O ERROR C14A3 ESTA A BARRAR-ME E NAO ACEITA MAIS NADA A FUNCIONAR
Feb 06, 2014 | Bernina Sewing Machines
Aug 12, 2009 | Bernina Bernette 75
Sewing Machines Logo
156 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
