Question about Sharp HT-DP3000 System
Where can I get a speaker connector? - Sharp HT-DP3000 System
    Problem Solver:
  • 4 Answers
After a few hours of looking on line and finding nothing I decided to make my own Sharp Receiver connectors. Here are the steps that I took:
where can I get a - _1349.jpgItems I used were wire strippers, wire snips, a file and a sugar free Rockstar (not pictured items: computer power supply, fine grit sandpaper and zip-ties).
_1350.jpg The first this I did was find the 4 pin connector and the 20 pin connector (some times a 16 pin) on the pc power supply and i cut the wires so that there was about 10" to 12" of wire hanging from each connector. These are the 2 connectors need from the power supply to use in your Sharp Receiver.
_1351.jpg This is the smaller of the 2 connectors (the 4 pin) and nothing needs to be done with this one. It fits perfectly into the back of the Sharp Receiver into the area labeled " surround sound". I would just zip tie the wires 3" from the connector and then 6" from the connector.
where can I get a - _1352.jpg"http://i.fixya.net/uploads/images/_1352.jpg" alt="_1352.jpg" class="h_mi" /> The large connector I cut from the pc power supply is the one where all the work needs to be done. The Sharp Receiver requires an 8 pin connector for the are labeled "front speakers/center speakers/sub woofer". Notice the location of the clip for this connector and that it is centered, we need this clip to remain in the center when we are done so re are going to have to remove every thing from it except for the center 8 pins.
_1353.jpg What I did to get the connector to look like this picture is I cut the 6 pins off on both ends of the connector (you would only cut the 4 pins off both end if you are using a 16 pin connector from the power supply). after I cut those pins off I just pulled the wires out from the back side (they come out very easy after you cut the pins off). Now we need to get rid of the extra plastic where we cut the pins. Please view the next 2 pictures before you beginwhere can I get a - _1354.jpgur cut.
_1355.jpg Notice how I left the plastic intact surrounding the 8 remaining pins we are using. I know that it seems like common sense to do it this way but there's people out there who would have cut the plastic so the pins we need are showing. There may be some jagged edged now from where u cut the extra plastic so to get rid of that we are going to use a file or a grinder. Don't grind the sides completely down though, I left a little bit of the ridges because the new ends have thin plastic walls and if you leave a where can I get a - _1356.jpg the ridges, it will make it a little stronger.
_1356.jpg I tried to put my, now 8 pin, connector in the back of my Sharp Receiver and it was really snug. This is where the fine grit sandpaper comes in handy. just go around each of the 8 pins with the sandpaper, not a lot, just enough so the pins slide into the plug easy and doesn't wiggle. I used 2 zip-ties on this connector also to secure the wired a little more. Again, 3" and 6" from the connector. Now its ready to bwhere can I get a - _1357.jpg into the area labeled "front speakers/center speakers/sub woofer".
_1357.jpg This is what it should look like when you are all done making the speaker connectors for your Sharp Receiver. All that's left is to connect your speaker wires to your speaker connectors and then all of your components.
I only found 1 website that had the parts for this unit for sale and it was about $50 plus shipping for the connectors. You can get the computer power supply from your local area on www.craigslist.org for $5 or $10, you might have one lying around. If you have any questions or need additional help with this please feel free to email me: jlusk80 @ gmail.com
Thanks for reading my solution!
Posted on May 26, 2011
    New Friend:
    Problem Solver:
  • 3 Answers
Awesome! I should've thought of this but I'm glad you did :-D
Posted on Jan 05, 2015
What or the color of the radio wires for in a 1993 bonneville
Use a multimeter to find the two feeds and then a 9v pp3 battery to check the speakers it thats simple .
Feb 25, 2012 | 1993 Pontiac Bonneville
I am looking for speakers to replace the ones that r in it.They r they original speakers that came with the car. Delco speakers-they have 1 adapter female plug on each side of the back speakers. Can't find...
any aftermarket speaker you buy will not have that style plug. you need to cut off the original connector on the wiring, and use the connector for the aftermarket speakers - there are a couple different style connectors, whoever you buy the speakers from can provide the proper connectors that you will crimp onto the wiring. good luck!
May 10, 2010 | 2000 Pontiac Grand Am GT
How do i connect the speakers to my computer?
Step 1 Connect the green connector
from the subwoofer into the green jack on the computer
(the black connector is not used)
Step 2 Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3 Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4 Plug the AC plug into the wall outlet.
Step 5 Turn on the speaker set and adjust the volume accordingly.
Jan 22, 2010 | Harman Kardon HK695 Computer Speakers
What does speaker cord for eT3205 look like? May not have been in
No question is stupid but it would help if you gave more information.
The basic cord for any speaker is 1/8" audio connector...
Nov 07, 2009 | Audio Players & Recorders
I have got 2CH speakers idont know where to plug in to the CPU
There are usually 3 audio connectors on a sound card. For Line in, headphone/line out and microphone. The connectors maybe connected to the motherboard or there is a separate sound card.
These connectors are 2.5mm audio sockets - connect the speakers to the headphone/line out (usually green).
If you are not sure which connector to plug the speakers in, just start a audio CD and plug the speaker plug into each socket connector until you get music from the speakers. You will not damage anything if you plug the speakers in the wrong audio socket.
Oct 24, 2009 | Acer X193W LCD Monitor
I want to connect the z2300 speakers to an LCD tv. Do I need a special cable?
try to check your speaker if what type of cable your speaker have...your LCD tv i think its a RCA connector, so you have to insert the RCA connector to the output audio label,,,then the cable which is also an RCA output must be connected to a RCA female connector ....again the output the your female connector will depend to what your speaker output have....it its minijack or RCA then the output must be female RCA of mini jack also.
Oct 19, 2009 | Logitech Z-2300 Computer Speakers
Need connector to a sony sa-va1 right and left speakers
Are you looking for connectors on speakers or need wires that hooked in speaker and home theater system?
Please intimate model number that is written on main home theater system to provide you info about speaker wires.
Jul 11, 2009 | Sony SA-VA1 Rear Speaker
Speaker cut out
The problem sounds like either the connectors from the radio to the speakers disconnecting.
To fix this I suggest you work out which speaker is getting is cutting in and out. Then you take the speaker out and check the connectors are attached to the speaker correctly. If the connectors are loose or don't have dirt or something stopping the from making a clean connection the speaker this can cause a problem.
If after checking the speaker connectors the problem persists you need to take the radio out can check the connectors on the radio have not come loose or anything.
If it still doesn't work after that I would then look to replace the radio, as if the speakers are working some of the time that would mean that the problem is probably with the radio not the speakers.
Hope that helps
Feb 05, 2009 | 1998 Ford Contour
No sound, cenral and rear speakers Dell 5650 speakers
the surround sound speakers connect to the computer by way of three connectors. the system should have come with an adapter that plugs all three connectors into one green connector. if you color match that green connector into the computer you should get sound out of the central and rear speakers. not sure if the surround sound will work correctly for movies, but you should get sound
Jan 20, 2009 | Dell 5650 Computer Speakers
Dual Cube speakers
Remove grill from speaker that has the snap connector. Remove 4 screws, gently pull out speaker and padding. Put pressure on connector (making sure the connector is out at the max. position)with middle and index finger at the same time placing other speaker onto connector, slightly turning speaker. You will here it snap in. Just use maximum pressure with fingers. Do not use tools. Connector is made of plastic and can break very easy.
Sep 08, 2007 | Bose Acoustimass 5 III System
Sharp HT-DP3000 System Logo
884 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
