Question about polaris ranger rzr
2007 ranger xp, new battery wont start any ideas
    Genius:
  • Polaris Master
  • 1,508 Answers
Are you referring to the ranger kids toy?
Posted on May 14, 2012
New starter, new battery, terminals all clean, battery tests 12.8 . Turns over slowly doesn't start any help?
Fully charged battery should read 14.4 volts. Try a jump from a running car, see if that helps. If not, your engine may be siezed.
Dec 21, 2015 | Polaris 2007 Ranger 4x4 EFI
I have a 2007 Ranger 6 cyclinder and it stalled and now will not start and the rear lights are dim or do not show at all?
I just got rid of my 2004 Ranger w/4.0v6. Never had that issue. You need to have the battery load tested first. Then have the alternator checked out.
Aug 04, 2014 | 2007 Ford Ranger 4.0
2007 polaris ranger 700 xp stop running all at once will not crank
sounds like a problem with the charging system on the battery. take a volt meter and check the voltage on the battery. If its lower than what the nameplate voltage is, it wont produce enough power to crank the engine. also check the wire connections.
Sep 19, 2012 | Polaris ATV
It wont start, just makes a clicking noise. put new battery cables on, new starter, new cylinoid. tried to jump start it, wont jump start either
Clicking noise usually means a bad connection at the battery terminal. It can also be a bad connection at the starter or solenoid.
Re-clean and tighten battery cables,and if that doesn't do it,re-tighten starter connections.Don't overtighten as copper-bronze studs can break easily.If your Ranger is standard shift (4 or 5-speed), don't get under the car or in front of it without the battery cables disconnectede or the shifter in neutral,as any current you inadvertently send thru the starter can engage it and run you over or knock the vehicle off jackstands or blocks. don-ohio
Oct 13, 2011 | 1992 Ford Ranger
96 Ranger new battery new solenoid new starter. Can roll it and pop the clutch, but key wont start. Everything turns on but no click when I turn the key.
Hello
I had the same problem with mine. It ended up being the neutral safety switch connected to the clutch pedal. At least with mine you had to hold down the clutch or the truck didnt think it was in neutral. No neutral means it wont start.
I hope that helps
Nov 25, 2010 | 1996 Ford Ranger SuperCab
2007 yamaha touring dead battery
jump starting battery in the frame not generally a good idea.take battery out and use a charger to replenish battery.are their in line fuses on battery leads,check these to ensure continuity
Mar 01, 2010 | 2007 Yamaha Royal Star Venture
I have power but my 1990 ford ranger clicks loudly and wont turn
Starter could be stuck..
If you are SURE you battery is fully charged with no dead cells..
Try --
(takes 2 peopl) -
Turn the key like you are trying to start it.
At the SAME time - smack the starter with a small hammer not too too hard..
Let me know what happens..
Jul 09, 2009 | 1998 Ford Ranger SuperCab
Truck wont start just clicks.
either a bad body ground,or your tranny is locked up,did it run good before you shut it off?
Mar 11, 2009 | 1992 Ford Ranger
polaris ranger rzr Logo
120 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
