Question about Matsonic MS9317E Motherboard
Sound on the computer
The computer cannot detect the drivers of the sound.when tried to install the new drives there´s a message that sai´s"your computer is not equipped with our sound chip".what´s wrong???
  • 137 Answers
Click Start > Run > type devmgmt.msc > click OK > if you see that you have Sound device, check if it's working properly. If it isn't uninstall it from device manager and then restart computer. hopefully windows will recignize the hardware and reinstall the drivers for you automatically.
Posted on Jul 08, 2008
Disk drive disapeared
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Sep 05, 2012 | eMachines Computers & Internet
CD Burner doesnt see a Disc is in already
ok..sounds like maybe your cd drivers are kaput...what computer are you using?
Mar 25, 2008 | TDK veloCD CD-RW Burner
Where can i download driver for hp v165w USB flash
The USB driver installed by default. U need not have to install it separately. If it is not recognised then try to use it on another system, see whether it gets connected or not
Apr 19, 2010 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
My HP compaq d530 doesn't detect any USB drive. I'm trying to upload a sound driver onto it and I don't have a CD. I put the driver onto a USB drive but the computer doesn't detect the drive. I just...
So we have two problems one your sound is not working and two your usb drive is not detecting any connected devices, correct?
Starting with the sound simply use a friends computer to burn the audio driver onto a cd. Next install the driver on your machine.
Problem two the usb. Remove the flash drive and try plugging in any other usb device such as a printer or camer or cell phone and see if windows says found new hardware. You don't need to install it this will simply tell you if your usb port is functioning or has a problem. if you do get a found new hardware message then your usb port is functioning and may only have a problem seeing your flash drive. Try uninstalling the usb port in System Properties. Right click on My Computer then left click on Properties. Now click on the Hardware tab. Now click on Device manager. Now go to the bottom where the usb devices are and uninstall all usb devices and when your done restart the machine. See if you can use your flash drive now. Other wise check your bios settings for the usb devices to see that they are infact set correctly and if you cant do this take it to your local pc repair shop and they can do this for you.
Hope this helps.
Sep 24, 2009 | HP Compaq d530 CMT PC Desktop
Computer not detecting my motorola z6m
Try changing d port. It always work. If not switch off ur mobile then switch on.
Aug 19, 2009 | Motorola Mobility L6 Cellular Phone
Network adapter not installed or not present message
Restart your computer in safe mode. Press F8 while rebooting. Once in safe mode, go to Start - control Panel - system. Right click on and remove the network card devices (you might see more of them there than you do in normal mode). Then restart the computer.
It should detect the new card and allow you to install the drivers for it. If it still doesn't detect the new NIC card, try powering off the machine. Open the case, and make sure the card is properly seated inside the computer case. Press down on it firmly. Then restart and see if it detects the card.
If it doesn't detect the card, the card might be bad. If you have another card, I'd suggest trying a different one, to see if it recognizes a card that you know is good.
Try these things and let me know how it goes. Thanks.
-Asaph
Jan 20, 2009 | HP Broadcom NetXtreme Network Adapter
Pci error
I would suggest that you cancel the device installation, download the drivers for various components (Sound, Chipset, Network etc.) from the HP website. Install those drivers and restart. Check if that new device found message comes again and let me know.
Hope it helps.
Love.
Jan 14, 2009 | HP Compaq dx2300 Microtower - RT950UTABA...
My computer cannot detect multimedia audio controller
Download Microsoft UAA driver then install it
Uninstall any sound driver first then
Go to device drivers and update your sound driver will go on net and find them and install them
Nov 01, 2008 | ASUS P5S800-VM Motherboard
Sound of computer
Basically ya must go control panel ... Device Manager .....select ya sound adapter and "Remove hardware/Driver" when asked if ya want to completely remove .... say YES & finish.. Then restart ya PC, and windows will/should detect ya hardware/sound-card and ask for the "Drivers" point it to the "Drivers" either on CD or files on Hard Drive... IF windows doesn't "Detect" & "Just Work", Well then ya sound-card has probably faulted.. ya could try another PCI slot... to be sure... but it looks like at this stage ya drive is borked.
Sep 09, 2007 | Audio Players & Recorders
Matsonic MS9317E Motherboard Logo
269 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
