Question about Maytag MER5530 Electric Kitchen Range
Why does the large front burner stay on high heat even when turned to low heat?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you have a defective burner control valve.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
Front large burner will heat up to red hot sometime recardless of what the temperture is turned to
Hello. I can be of more help with a model number. Is this a glass top? When this element is on, low for example does it cycle on and of repeatedly? When On HIGH does it stay on all the time?
Apr 08, 2014 | Whirlpool Kitchen Ranges
I have a Beaumark Electric range about 8 years old, The right front burner comes on high as soon as it is turned on, even if I turn it to low it remains on very, very high and burns everything. Why
The burner is not controlled and so it is possible that there is no control on the heating coils.The thermostat settings must be checked as this can be an area where the coils are not controlled for the heat set but goes to the highest level.You will need to remove the unit to check the control action of the controller, check the thermostat and sensor.
Nov 22, 2011 | Kitchen Ranges
Large right/front burner is out of control. Regardless of the setting, the burner heats very high. In fact, recently, oliver oil in a skillet ignited. Even though the control was set to less than medium,...
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
GENE
Sep 23, 2011 | GE Cooktops
Dual top burner will only heat up on high.It is only the large ring burner GE JBP79
Does it go straight to full heat even though it is on the low setting. If this is the case the hotplate controller is faulty and requires replacement.
Feb 24, 2011 | GE Spectra JBP78 Electric Kitchen Range
Burner heats to high even when set on low
Are you talking about the cook-top part of this unit or the interior of the oven? If it's the top part, your infinite switch is out. If it's the interior, it's one of the elememts. If you will give us a call as soon as you get a chance, we'll make sure and get the correct part out to you right away to get this repaired. We look forward to working with you and getting your oven fixed BEFORE Thanksgiving. 972-859-0929
Oct 04, 2009 | Ovens
Burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
Jun 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
I have a Inglis smooth top stove, model IME 8230. One of the front has a dial for single/dual --for quick heat up. It was working fine, til couple of days ago, it suddenly went haywire. When I turned it...
The swich for the burner is bad and needs to be replaced. The glass will be fine, but unless your just boiling water you wont be abe to use it until you replace the switch.
Apr 08, 2008 | Kitchen Ranges
Maytag MER5530 Electric Kitchen Range Logo
69 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
