Question about Dishwashers
Whirlpool dishwasher model DUB700XB has quit cycling. Fills with water but will not start wash cycle. Making intermittent humming noise unless the door is open to disengage the switch, even when on stop. No LEDs lighting when rotating the dial through the various cycles. Unit is old and wondering if it's better to buy a new one rather than fix this and have something else go wrong in the not to distant future. Thanks in advance
catriver
  • 878 Answers
SOURCE: Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Posted on Dec 30, 2006
SOURCE: Whirlpool Dishwasher Model ADG 7560 Unit
found outlet pipe was kinked, stopping water flow
Posted on Sep 09, 2008
SOURCE: noisy dishwasher
i have aloud buzzing nose and humming what is the problem
Posted on Nov 26, 2008
here2helpBSH
  • 27 Answers
SOURCE: Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Posted on Mar 19, 2009
  • 423 Answers
SOURCE: Dishwasher making loud humming noise
The most common cause of the hum/grinding sound, and often poor cleaning - is a blocked filter or debris stuck below that filter.
Pretty easy fix: Get a phillips screwdriver near by. Pull out the lower rack (the upper rack can come out if you pull the little gray thingeys on the front of the upper rails.)
Remove the lower spray arm -- just pull it straight up. Remove nine silver screws from the sump area that holds the filter down. Pull the filter up and out. Rinse the filter as best you can.
While the filter removed, with a flash light inspect all over the sump area - looking for stuff that should not be there and clean it out. Watch out for broken glass!
Replace the filter, screws and the spray arm. Fire it up and check your results!
Good Luck!
Posted on Apr 04, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kitchenaid kuds02frss1
The wash pump and drain pump are different. So it is likely the wash pump is choked and trips or the motor is faulty.
http://www.searspartsdirect.com/partsdirect/part-model/KITCHENAID-Parts/Dishwasher-Parts/Model-KUDS02FRSS0/0593/0130000/W0602076/00008?blt=06&prst=&shdMod=#
It is likely the flap valve (item 5) or the chopper (item 6) are damaged and could be replaced before you get to the wash motor.
Apr 17, 2014 | Dishwashers
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
Turn dishwasher on . the water loads in and then goes into wash cycle, it does it's wash cycle then drains and will not load clean water for rinse cycle it just hums a and then quits, then tries again and...
Tim Derbowka, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Tim Derbowka), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool GU2300XTS 24 in Builtin...
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
LOUD HUMMING AFTER WATER FILLS AT START OF CYCLE
Sounds like you have something in the sump/motor. I could lead you through it on a chat session but too much just to type. Let me know if you would like me to do so.
Mar 04, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Dishwashers Logo
160 people viewed this question
Top Dishwashers Experts
