Question about Humminbird 787c2 Combo GPS Receiver
My Humminbird 788 ci screen clutters up and gives crazy depth readings when the trolling motor (mk terrpva80# w/ ipilot and built in td w/mkr-us2-8 cable) is set on mid to high speed settings. It does this most- but not all times...any ideas? thanks, Rob
  • 29 Answers
One thing you might try is restoring the defaults in your unit. One other thing is go into the menu under the sonar tab and adjust your Noise Filter. You may have some type of interference going on. You can call our customer service department and they will trouble shoot it for you. Our number is 800-633-1468.
Joby from Humminbird.
Posted on Jan 03, 2011
How to connect Humminbird fish finder to Motorguide trolling motor
I would use slip rings to tie existing cable to prop motor support shaft and mount transducer to motor housing. 'slip ring'--metal ring a little bigger than shaft with a nipple the size of the cable. OR call the bird at 1-800-633-1468 or www.humminbird.com/Category/Company/Contact-Us/ and use some southern/country slang when talking. Best of luck 'you all'.
Oct 03, 2016 | Humminbird Boating
Why does my fish finder sieze up when i start my boat?
it seizes up because their is a very hi draw on your battery when the motor is turning over, the starter draws so much power from the battery that it drops the voltage down below what the depth finder needs
Aug 11, 2014 | Humminbird 597 Ci Hd Combo Sonar/Gps
Minn Kota mk25 light will not move from yellow to green. I have moved the connections from one battery to another. I replaced a dead starter battery, and my trolling battery tested out at 100%. what could...
Do you remove the trolling motor wires before charging..? ...If not.. try that......mine started taking a LONG time to charge.. after I remove the trolling motor cables.. it take less time and charges better!!!
Feb 25, 2013 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Find manual for humminbird Wide W, serial#6376462
Here is a helpful link for the Humminbird manuals.
http://www.humminbird.com/support/ProductManuals.aspx
Aug 30, 2011 | Humminbird Wide Side Trolling Motor...
My dept finder reads gives me the wrong depth. Is there a way to calibrate this. I doint know the modle off hand. It is the one that gives you two side views and stright dowm. It has the temp. and speed.
If your depth is off because of where your transducer is located, calibration can be done through the menu by adding or subtracting a foot or two.  In your never to be read manual are all the instructions necessary.  If you are off by more than a foot or 2, chances are your transducer is bad.
http://www.humminbird.com/support/ProductManuals.aspx should allow you to download the manual for free and even step you through some troubleshooting.
Aug 09, 2011 | Humminbird Sport & Outdoor - Others
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
My 570 transducer is mounted on trolling motor.
I too have the exact same problem. .6 to 6ft then stays at .6. love to figure this out.
May 08, 2010 | Humminbird Smartcast Rf 35 Dual Display...
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Jul 27, 2009 | Minn Kota Maxxum 70 Universal Motor/Sonar...
Humminbird 787c2 Combo GPS Receiver Logo
354 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
