Question about Salton Coffee Makers & Espresso Machines
Salton quick mill grinder model GC-4 needs a new top. Any suggestions?
ftbrunswick3
SOURCE: salton coffee mill model cm-4
I just bought this model at a goodwill and I think the burr grinder is worn so it doesn;t grind fine enough - the storage chamber and lid and the top lid are all in great shape - you can have them if you cover shipping and the price I paid (I paid $4)......I am thinking (?) you can respond to my post and I will get notification - and we can figure out how to do this......Kathy Fremont, Michigan
Posted on Apr 12, 2016
http://www.mrcoffee.com/Products.aspx?cid=44&Page=2
this link had few products and manuals,see if you can find yours..
Posted on Nov 23, 2008
Does the phrase up the creek ring a bell?
Posted on May 26, 2009
  • 474 Answers
SOURCE: I am trying to dissasemble my A9 grinder to clean
Left hand threads.
Posted on Feb 22, 2011
vko007us
  • 254 Answers
SOURCE: How do I clean my coffee mill/grinder (Models
Clean your coffee mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Unplug your coffee mill.
  2. DO NOT PLACE THIS COFFEE MILL IN WATER. DO NOT IMMERSE THE BLADES OR MOTOR BASE IN WATER.
  3. Remove the coffee mill cover and brush. Wash both in warm sudsy water. Rinse and dry each thoroughly. The cover and brush are NOT dishwasher safe.
  4. Use the Built-In Cleaning Brush to sweep out excess grounds. Use a clean cloth or paper towel to remove any remaining grounds.
  5. Be sure to clean your coffee mill completely after each use.
  6. Do not try to oil or sharpen the blades. The blades are permanently lubricated and never need sharpening.
Posted on Sep 02, 2011
Lattefarms@yahoo.com
Remove the grinder tray, remove the grinder top and clean out the burrs.
lift the command unit. close and remove the bean hopper. Press in the two thumb tabs either side of the grinder tray and pull the tray forward. If it's not been removed for a while it could be very tight. Push the tray in first then pull.
with the grinder tray removed, take out the white plastic ring that the hopper sits on. Unscrew the two Philips head screws in the top section of the grinder. Remove the screws and rotate the top section anti clockwise whilst lifting off. You should now have access the the grinder burrs. Carefully clean every part of the teeth burrs with a stiff brush or small screwdriver.
turn the tray over and examine the bottom end of the shaft which passes through the grinder. The centre is usually rubber and this can become detached with age. If the rubber is shot you will need to replace the pulley shaft. Check to the tension of the belt From the motor to the pulley shaft
Once everything is clean and clear, reverse the process to reassemble the machine.
you should find it now grinds ok
Jun 17, 2014 | Coffee Makers & Espresso Machines
Salton quick mill disassembly
last four digits of phone
Jun 20, 2013 | Food Processors
I have an old Craftsman bench grinder that I got at an auction. I need a capacitor and the one on it has no markings. It is a 1hp model 319.19063. Sears Parts direct says that it is no longer available and...
this is a "Split-Phase"motor it uses only a run capacitor and a typical capacitance rated MFD rating will be between 80 and 290 MFD, go to www. grainger..com and they will have your part,and even if its an older unit and the model/serial/number is available take it with you & they will have a replacement capacitor available in the correct size/dimension/mfd/etc
Apr 24, 2011 | Baldor 8" 1 Hp Electric Bench Grinder
I received a se of Russell Hobbs Salt & Pepper Mills as a Christmas gift. But after only 4.1/2 months the salt mill doesn't work. I have replaced the batteries, swapped the head from the pepper mill,...
Hi Lorraine.
You'll need to talk to Salton Appliances in Melbourne. They are the Australian importer for Russell Hobbs.
Phone: 1800 427 842
Email: info@salton.com.au
BTW This is not their direct site so I recommend you delete all of your personal contact info from here.
Regards from Nowra :)
May 21, 2010 | Kitchen Appliances - Others
What are the maintenance procedures for the Pasquini mod. GMMC coffee grinder?
If this is in reference to the Pasquini K2 Moka Grinder, they are pretty much maintence free. Remove the beans/hopper, then pushing the button on left hand side down, you can unscrew the dial counter-clockwise. This will give you access to the top/bottom mills. Use a wire brush the machine came with to clean the coffee off from the mills teeth which builds up over time. Then reassumble and readjust your grind for the beans you are using.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Apr 06, 2010 | Pasquini Moka Coffee Grinder
Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Feb 04, 2009 | Zassenhaus Knee Mill Hand Crank 156 Manual...
DeLongi coffee mill #DCG-4TB
DeLonghi PARTS AND ACCESSORIES
1 (800) 865-6330.
8:30 a.m. – 5:00 p.m. (EST) Monday through Friday.
Oct 24, 2008 | DeLonghi Electric Coffee Mill Grinder
Coffee Makers & Espresso Machines Logo
180 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Anthony Turner
Level 1 Expert
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
