Question about Whirlpool Dryers
Dryer electric was hooked up wrong ... netural witer was in the hot side of the recepital ... black hot was in the netural position. I hooked it up correctely but now dryer does not turn on at all. We have the correct power to the back of the dryer through the cord.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Sounds like damage to motor or start switch on motor due to the cord wired incorrectly. You will more than likely have to replace the motor in the dryer.
Posted on Jan 02, 2011
Hooking electric wheelchair battery to the fuse box and when the positive touches it sparks and smokes....whats wrong
tiny spark sometime normal but not getting hot! batteries are hooked up wrong. check polarity double double double check them
Oct 18, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Hello, I have just purchased a frigidaire gallery series stackable combo 2004 model glet1142cso after hooking it up i am having problems. It won't fill unless dryer door is open..won't spin out...
Probably an auto tec installed the recepticle on the wall or in the electric pannel. in home electric the black wire and the red wires are hot. In automobiles the black is ground. You should have 240 volts between the two flat connectors on the plug when its pluged into the recepticle.
Dec 20, 2017 | Frigidaire FEX831F Top Load Stacked Washer...
Need the positions for a 4 wire hook up on a Maytag dryer PYE2300AYW
Red and Black will be the hot wires and the green will ground ..white wire is your neutral..
Green will be the top , White will be at the bottom red and black will side by side.. Hope this help
Dec 18, 2010 | Dryers
I need a wiring diagram hook up for a Jenn air 201595D Range top & also for a GE Double oven JKP36G0D1B0
Cook top manuals and installation.
http://www.jennair.com/catalog/product.jsp?parentCat=2&cat=12&prod=1457&tabOption=specs#info
Could not find installation manual on oven but did find manual. If you are just trying to wire to the house wiring you need to conect this way. Yo uwill have 3- 4 wires from the house. 1 white, 2 black or 1 black and 1 red. From range hook white to white Black to black or red they both are the hot line. and the other black or red to black or red from the house. If you have bare wires that is the ground There is 2 ways to do the hook up on the ground. 1st way is if you have ground in box from house wire them together. 2nd way is if there is no groung just wire it up with the white wire that is the netural line. It will be fine that way. If you can see in you main braker box the netural and the ground go to the same bus bar.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Good Luck and If you have any more ? fill free to ask befor you rate.
Jan 16, 2009 | Jenn-Air JED8430 Electric Cooktop
Wiring directions for Kenmore 800 Dryer
Hello mynexthome,
Sounds like you did everything correctly however it is possible the wall receptacle may be miswired. The white wire is the neutral, black and red are the line feeds ( hot ) and green is ground. If you are sure the receptacle is wired correctly and that the power cord is wired as you say it is, then there may be an internal issue with the dryer..or some packing material was not removed and is burning off. ( make sure the drum can spin freely and you aren't smelling a belt burning) The red and black are normally on either side of the neutral but you should match the color code on the terminal block on the dryer. Hope that helps...
Regards,
Rick
Jan 03, 2009 | Dryers
3 prong dryer to 4 prong
green is ground, white is netural. red and black are L1 and L2
or in other words on the dryer there is a 3 screw holder red and black go on the outer ones white goes in the middle and green goes to the cabinet of the dryer
Oct 31, 2008 | Frigidaire FEQ332E Electric Dryer
Wiring hook up in the back for whirpool dryer
assuming you are referring to the power hookup,there is no positive negative, (it's not D.C.) red and black are the hot lines(240 volt between them) white is neutral and green is equipment ground.voltage reading should be 120 volts from red or black to white as well as green, 240 volts from red to black, 0 volts from white to green
Sep 08, 2008 | Whirlpool GEW9250 Electric Dryer
Electric cord
What you should get is a new 4 wire cord. It is way less complicated than trying to change out the wall receptacle.
On a 4 wire dryer cord you have White(common) in the middle. Red and Black are hot and go on either side of white. If you really want to make it look good you can put red to red on the terminal and black to black but you don't have to. Some dryers may not have those color hot wires. Green hooks to the chassis with a green screw or any screw connected directly to the frame.
Jul 21, 2008 | Kenmore 62802 Electric Dryer
Ge dryer hooking up for prong cord
If the house is wired right you should be hooked up right. Sounds like it's not moving air properly. Check that the vent is not crushed behind it and that it flows clear all the way outside.
May 19, 2008 | Dryers
Whirl pool dryer
L1 Hot= Left terminal (Red Wire) ...... L2 Hot= Right side terminal (Black Wire) .......... Netural = Center terminal (White Wire) .................. Ground is Green connect to the cabniet of the unit and remove the connection strap from the center terminal on thje dryer wiring block..
Feb 22, 2008 | Kitchen Ranges
Open Questions:
Dryers Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
