Question about Kenmore Dryers
Kenmore Dryer My dryer won't start. It makes no sound when the start button is pushed. I turned it to all the settings and all are the same.
  • 95 Answers
Check your breaker first. Then check your power cord and outlet for burns
Posted on Jul 08, 2008
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
Kenmore dryer model 110.74994300 push start does not stay on
Jul 01, 2014 | Kenmore 62602 Electric Dryer
How can I fix my HE4 Gas dyer it will not start
Jun 21, 2014 | Kenmore 659 Electric Dryer
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 30, 2011 | Kenmore Dryers
My Kenmore dryer won't stay on when you push the start button it starts and turns off real quick. I have gotten new fuses and replaced them and it still won't work.
heatman101
Jun 01, 2011 | Dryers
My dryer won,t start. When you set the timer and turned the starter on you hear a sound that seems it will run but when you let go the starter it just won/t run
You have a bad motor. There should be a button you can press to make your dryer go while the door is open. Hold that and push the button in and then turn the drum. if that doesn't make it go then it is your motor
Apr 18, 2011 | Frigidaire Dryers
When I push the "push to start" button (knob) on
heatman101
Mar 14, 2011 | Kenmore Dryers
Kenmore dryer 500 electric, will not turn on, circuit breaker ok
Sounds like a broken belt or a faulty motor...
Sep 22, 2009 | Kenmore Dryers
Dryers Logo
46 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
