Question about Whirlpool Duet GHW9150P Front Load Washer
Door locked and unable to unlock to remove clothes. I notice that someone else had the same problem in August 2008. I do not know what a star tool is. Please help, I need to get my clothes out. Heck of a way to start a new year. :-(
  • 1,531 Answers
If you have a wet dry shop vac you can use it to remove the water from the unit.
Attach the vac to the end of the drain hose and remove the water once the water is removed then you will unplug the unit for a few seconds plug it back in and you should be able to unlock the door.
If that works then you will need to check the drain pump and hoses for any obstructions that may be restricting the flow of water.
Posted on Jan 01, 2011
  • vbarlow9 Jan 06, 2011
    There is no water in my washer and the detergent was never dispensed either. The F-28 just keeps flashing and despite having unplugged the machine for 2 days, it still will not reset and allow me to open the door when I plug it back in.
2008 VW golf central locking will not unlock passenger front door. Unable to open from inside either. Any suggestions please
remove door panel and check the locking rods possible rod clip broke or disconnected
Nov 10, 2016 | Cars & Trucks
Unlock Chevy spark with slim Jim
Most lock out companies use a long metal rod that is inserted through the top of the door and is then used to push the power door lock button or the lock button. If you gently pull on the top of the door and insert a wedge to keep the door ajar slightly, you can use a coat hanger and manoevere it to touch the door lock button
Sep 05, 2015 | Cars & Trucks
My washer stopped during the spin because it got out of balance. Now I am unable to open the door and my clothes are stuck in the machine.
Non of the answers are helpfull. Unplug power.Remove bottom panel and there you find a door lock release. Pull n the door will unlock. Drain water from from pum(it has drain tube). Remove clothes. Move n push the tub a little on each side. Now plug drain pipe. Close door n put it to spin. Should work
May 27, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Took my 2008 silverado to have it detailed, when I got it back all seats and carpeting were soaking wet, when i got it home to park it in the heated building to dry noticed the door locks didn't work and...
I'm sorry to hear about the troubles you are experiencing with your Silverado Jeanette. It sounds like the detailer may have gotten liquid inside the driver's door panel/armrest. Since you say the door locks still work with the fob and all the fuses checked good then I can only assume water intrusion in these switches is the problem. Water could also cause the speaker to short out and become non-functional. This year model truck is notorious for door lock actuator, power mirror, and speaker failure. I've had to replace all on my 2008 Silverado along with the mirror switch. There are several good videos posted on YouTube on how to troubleshoot these problems which may be helpful if you are a DIY kind of person. Otherwise you'll have to take it to a trustworthy mechanic to do the troubleshooting and repairs for you. Hopefully you know someone who is good at this sort of thing because the dealerships will charge you a small fortune to repair them. Have you contacted the detailer to see what he may do to help with the cost? It couldn't hurt!
Mar 30, 2015 | 2008 Chevrolet Silverado 1500
How do I unlock my 2008 Chevy Silverado Truck?
Slim Jims won't work on the door. There is a tool called The BigEasy unlock tool. You sneak it between the jam and door frame and hook it on the lock knob and pull it to unlock the door or push the power lock button to unlock the door.
Oct 12, 2014 | 2008 Chevrolet Silverado 1500 2WD
The rear passenger door won't unlock so I can't open it - it's doesn't appear to be the child lock
Common problem .door trim need to be removed to access inner door handle mechanisim .oyu need to get someone who knows what they are doing because it's very tricky.
Dec 22, 2013 | 2008 Hyundai Santa Fe GLS
I am unable to close the driver door. The metal piece in the door that wraps around the screw looking piece located in the door frame will not engage. Help...
Open the door & have someone hold it open,
with the door handle pulled out
Use a screw driver or any round tool to open the
plastic lock catch in the door latch
Sometimes your clothes catch it & close it ,as if it
were wrapped around the B-Pillar Pin, your referring to
Jul 09, 2012 | 2004 Cadillac Escalade
The battery is dead on my 2008 Ford Taurus X, the doors are locked and my keys won't unlock the door. Any help you can give me would be greatly appreciated. I've already tried the key less entry. That is...
I hate the way they have incorporated these new alarm systems so that you cant open the doors when the battery is dead, some cars will lock you inside unable to open door from inside. The electric door locks are what is keeping you from being able to unlock doors. Some people go to Auto Zone and rent the tool that can be slid into the door by way of the window opening, this doesn't always work. the best way to get in is to go under the car with a set of jumper cables and charge the battery from the large battery cable that is connected to the starter.. charge battery enough to access door locks P.s. it wont take much power to use key to unlock door after the battery has a small charge..
Mar 23, 2011 | 2008 Ford Taurus X
2008 chevrolet malibu door lock problem
My girlfriend has a 2008 Malibu. The door locks began to falter one by one until three of the locks had to be operated manually or by using a key. I checked the fuses, the BCM and the lubrication on the locks. The door lock actuators were the real problem. She was quoted about $1000 to fix the problem and replace all three of the bad actuator/ door lock assemblies through the dealer. I called and got a price of $125 for the front door and $105 for each of the back doors from the dealer. I was able to fix all three door locks in about three hours myself. It took a few star end bits, a 10 mm socket and a regular phillips screwdriver to get the job done. It has been two weeks now and she is ecstatic that the problem has been fixed and she saved about $750. This seems to be a common problem with this car, when ordering make sure you have the VIN number of the car you are working on to ensure you get the right part. Depending on the year of the vehicle there was a production date split for these parts.
Mar 07, 2010 | 2008 Chevrolet Malibu
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
154 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
