Question about HP Photosmart C7280 Printer
HP Photosmart C7180 all in one. error 0xc18a0106 please heeelp
ghost2233
  • 3606 Answers
SOURCE: I'm getting an error messege
Solution 1:
  • Push "OK", "Cancel", "Black" and "Color" all at once while turning the printer off.
  • Turn it back on.
  • One more time: push "OK", "Cancel", "Black" and "Color" all at once while turning the printer off.
  • Turn it back on.
Solution 2: Resetting the product:
  • Without turning off the product, disconnect the USB cable from the rear of the product.
  • Remove the cartridges from the product.
  • Wait for the "Insert Cartridges" message on the control panel.
  • Disconnect the power cord from the back of the product.
  • Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Reinsert the cartridges, and then close any open doors on the product.
  • If you receive a prompt to print a calibration page, do so.
  • Reconnect the USB cable to the rear of the product, and then try printing again.
Solution 3:
  • 1. Get the unit into the "Support Menu" by following these steps: Press and hold the "*" key. Press the "#" key and release both keys. Display should say "Enter Special Key Combo". Press and release in sequence the "1", "2" and "3" buttons. Display should say "Support"
  • 2. Press and release the right arrow button until the display says "System Configuration Menu".
  • 3. Press and release the "OK" button.
  • 4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
  • 5. Press and release the "OK" button.
  • 6. Display should say "Hardware failure status: Clear. Press OK to clear".
  • 7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  • 8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. DO NOT TRY TO PRINT AT THIS STAGE.
  • 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • 11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
  • 12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
  • 13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
  • 14. If the error is still there, or reoccurs replace the unit.
Posted on Feb 24, 2011
  • 240 Answers
SOURCE: print error code 0xc18a0107 hp photosmart c7180 All in One
that was a system error...
How long since that problem occurs..??
I suggest that you need to load another compatible firmware on that printer ...
thank you for using FIXYA!
Posted on May 23, 2009
smwsolutions
  • 73 Answers
SOURCE: printing error oxc18a0101
Try resetting the printer:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on.
Posted on Jul 19, 2009
SOURCE: error:oxc18a0206
Best solution by gyan 9 posted Dec 20 2009 worked! 3 hours of tinkering and I'm now getting consecutive print instructions outputting on my C7180. And my error code was 0xc18a0201 btw. Thank you so much.
Posted on Feb 27, 2010
vonnielsen
  • 169 Answers
SOURCE: I recieve Ink System failure
The error that you are having is a hardware issue, it means your printer has an Ink System Failure. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
Posted on Feb 04, 2011
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
I recieve Ink System failure error message with error code 0xc18a0206 on my HP PHOTOSMART C7180 ALL-IN-ONE PRINTER.
Feb 03, 2011 | HP Photosmart C7180 All-In-One InkJet...
Hp c7180 getting message ocx1a002f, any ideas?
Are you sure the error code is not 0xc....
It sounds like your C7180 has an internal error condition and may need to be reset. It may be easier for you to view this solution online from HP support:
An 0x.. error message displays
Dec 21, 2009 | HP Photosmart C7180 All-In-One InkJet...
Hp photosmart 3313 all in one
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support. If you need their contact info I can give it to you.
Thanks,
Lee
Jun 17, 2008 | HP Photosmart 3210 Printer
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
Error message
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support, if you are not getting ink system failure along with Error 0xc18a0106 then power cycle the printer and then reset, this will resolve the issue.
Jul 03, 2007 | HP Photosmart 3210 Printer
HP Photosmart C7280 Printer Logo
742 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
