Question about Sharp XL-HP515 CD Shelf System
Sharp xl-dk225 shelf system
Hi there, when I turn on my stereo it sounds great after 15 min there is a small buzz that starts than gets louder untill it's so loud I have to turn it off. I took the top case off to see if I can tell where the buzzing is, it seems to come from a transformer if that is it, how can I quite it? or is it a capacitor in a filter circuit? can't tell which one, or is it something else?????
  • 1 more comment
  • junbug20 Jul 09, 2008
    Thank you for you r answer, I figured as much, I did turn the volume down your right it still was buzzing, what elsr inside can do this? can I replace the xformer myself?
    very helpful! thank Benimur! now where can I get a schematic? I am a tech by trade but I don't work on stereo's thanks again!
  • junbug20 Jul 10, 2008
    Thanks Benimur! I found a manual on manualparadise.com, yea I had
    to pay but not much and was able to download and get it fast, it is the
    xformer, it's a bear trying to find a new one. They did a real sloppy
    job of soldering the xformer on the PCB when I opened the case to get
    a better look, sheesh no pride in there work I guess. If I run into
    another problem I'll certainly look you up! thanks again.
    -junbug20
    Brigadier General:
  • 6,966 Answers
If you have verified that the transformer is the source/cause of the buzz, then chances are that it is a case of loose core. In some, small/long bolts with nuts are used to clamp the core together while other uses a combo or varnish and clamps. Having said this, then the problem is mechanically induced and therefore would require simply tightening of the bolts or clamping the cover/core. It might also be of help to check for any mechanically loose component/object near the transformer;
If the problem is a power supply capacitor, then it would not be a buzz but rather a hum;
If the problem is a small value capacitor in the pre-amp circuitry, then the level of the humming/buzzing sound is controllable through the volume control.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 09, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Jul 09, 2008
    Hi again,
    Sorry, as of the moment no free download of the schematics nor the service manual. You may want to try here or here (but it would seem for a fee).
    Again, good luck.
  • Louie  Role
    A comparable model XL-520W. May not be exactly the same but you may be able to get additional info or wing it from there. Service Manual if available here.
  • Louie  Role
    Louie Role Jul 10, 2008
    Glad to be of assistance and appreciate the rating. Would look forward should you be posting again.
    Cheers.
  • 6,487 Answers
Try this when the buzzing is there turn the sound down see if its still there if so then suspect a transformer or something inside and should go back to a factory service center near you.
Hope that helps.....
Posted on Jul 08, 2008
  • Sharp Master
  • 19,396 Answers
You need to identify the fault using a multimeter
  • Ginko
    Ginko Jul 08, 2008
    First you need to test the capacitor and the parts and components related to the area from where the noise comes, presumably the power supply area, and the amp area, which usually can give this kind of problems.
    Once you find the fault replace the part.
    If you need a multimeter, here is one.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Why does my projector make a very loud buzzing sound.
the buzzing sound will be a frequency vibration from the mains power cycles
check for loose connections, transformer mounts, loose bulb or any thing else that can vibrate
Apr 27, 2015 | Epson Powerlite 1720 Lcd Projector 3000...
Hi, I have a BEHRINGER V-Tone GMX212, I left it
Did you left the amp on overnight with a guitar hooked up to it?
Oct 29, 2013 | Behringer V Tone GMX212 2X60 Watt Stereo...
My TV takes about 15 minutes to start playing.
It sounds like you have a problem with your signal board. The signal board will need to be replaced.
you can get parts for this tv at www.interliquidparts.com
Feb 22, 2012 | Televison & Video
Refridgerator is clicking on loudly then buzzing and sizzling
I bet the Iemaker arm has been turned on allowing th eicemaker to cycle every 10-15 mins when the icemaker calls for water it causes the water valve to open. with no water connected to the unit the valve buzzes loudly causing your noise. make sure the icemaker arm is in the up position thus turning the i/m off thanks peyton
Mar 22, 2009 | Refrigerators
Buzzing sound through the speakers
Sounds like you are getting interferance from something like a cordless phone, TV, Computer something like that.
Feb 08, 2009 | RCA RT2280 System
Van runs great until it heats up. generally about 15-20 min.
i would check to see if your fuel pump is working properly maybe first try replacing the fuel filter and running a fuel treatment.
May 23, 2008 | 1996 Nissan Quest
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Jan 18, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Sharp XL-HP515 CD Shelf System Logo
124 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
