Question about Frigidaire 24" Built-in Single Electric Wall Oven - Black (Special Order)
Inherited uncle's house that has an old electri-clean cookmaster oven. the element is not working but the fan comes on when you turn in on...can't find the serial number to get the look for correct part or manual....i need help!!! What is a kitchen without a working oven???
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
without the model number, you will need to have a service company, come and look at the unit,
tell them on the phone, that you dont have a number, and to send their most experienced person. then they can match a coil up....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Have Ck90g232 model,electric oven has no heat,the fan still works but not the light. All other ovens and hobs are functioning,is this an element issue and will a professional have to fix the problem?
The light may just be a burned out light bulb. Remove it and take it to an appliance store to find a replacement. As far as the oven goes, elements do burn out. They are relatively inexpensive. Make sure you have turned the oven OFF before you do anything. The heating elements do pull out and you can replace them yourself. Take the information about your oven and the heating element to an appliance store for a direct replacement.
Nov 15, 2017 | Ovens Ovens
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
I have a hotpoint ew91 oven that stopped working after tripping house fuse. after resetting fuse fan works but no heat.
It is most likely that the oven heating element has failed which caused the house fuse to trip.
The replace the heating element will mean taking the back off the oven and removing the old heat element by undoing the fixing screws and the electrical connectors( normally this surrounds the fan assembly).
Fitting the new heat element should then be straight forward.
Remember to disconnect the power to the oven before removing the back.
Dec 09, 2010 | Ovens
Hi right my indesit 29229 fan oven is not working it blow the power in the house now the top oven is work but the bottom one wont heat up the fans working and thats it do you think its the element thats...
To blow the house trips it must be the element
Thermostats do not normally go short circuit.
The elements can be replaced quite easliy and cheaply
I would check that the fan is turning freely before you buy the element
Feb 24, 2010 | Ovens
Maytag electri single oven, not getting hot enough?
replace the lower element. easy fix. TURN OFF POWER. remove two screws inside that hold element in place. Pull forward. disconnect clips that connect wire to element. reverse steps to replace with new element.
Feb 28, 2009 | Maytag CWE4800A Electric Single Oven
Main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
Dec 13, 2008 | Zanussi Ovens
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
My fan doesn't work
fan not fixable - replace. possible be that there is crap jamming the fan.check that the fan blade turns freely
Mar 13, 2007 | Belling XOU492 Electric Double Oven
Frigidaire 24" Built-in Single Electric Wall Oven - Black (Special Order) Logo
131 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
