Question about Hamilton Beach 80355 Custom Grind Coffee Grinder
Change broken blade how to stop motor from turning
Remington BHT-2000 stopped working - missing/broken link between motor and blade?
yes there is something disconnected or broken the high pitched noise is because of the lost resistance from the blades 2 years full warranty .
If no warranty anymore is on it ask for Pricing for repairs ,because there can bemore differend prices on some models. that only a complete part must buyed that a complete new razor body is cheaper then the loose spare part. some marketing technical creations can have remarkable prices. thats why i know it will be a wise decision to inquire first advance because of and
To avoid repeating complaints if something is the cause on it and the problem will repeat the cause in a short time.
May 14, 2016 | Remington BHT2000 Hair Trimmer
Motor runs but blade stops 1" into the wood
Seems like it could be a clutch/drum issue. I have known clutches to break through the threads in the crank shaft so they appear tight but are actually broken. I'd look at the drum assembly to see why the drive to the chain is slipping.
Feb 17, 2013 | Stihl 009/010/011 Clutch/sprocket
1999 Cadillac Deville wiper blade on driver side not moving
bent/broken wiper arms under the base of the windshield..remove the vent cover and service/replace broken parts.
Feb 09, 2013 | 1999 Cadillac DeVille
My S107g worked great for a week but then the top blade just stopped moving. The lower blade is spinning away and the top one sits there limp. What's going on?
well firstly you still have warranty on it, get them to replace it..
the blades are controlled by a motor and a gear system in the helicopter itself. The gear is broken or the motor is wedged in by the gear. or simply burnt out, You will need to open it to unwedge the gear and if it spins when you turn the gear, you need to replace the motor. Both blades use separate motors that's what allows it to trim (turn) when one set spins faster than the other, It goes straight when both blades spin at the same speed.
Dec 29, 2012 | SYMA Toys industrial New Syma S107 Radio...
Makita 2012nb planer. The drive (top) sprocket keeps stripping out the flats on its arbor hole and the allen bolt loosens and backs out. Not sure which happens first. I've tried high strength loctite...
I think your screw is broken you should change the screw which attach the rollers and the blade. If you start a machine, screw turn out and let the roller stop rolling that means your screw and the ring are broken, you have to change them.
May 08, 2011 | Makita 2012NB Electric Planers
I have an older model black and decker miter saw. How do you change the blade? I can't seem to stop the motor shaft from turning in order to loosen the nut to remove the blade?
Hi, you need to look thoroughly at the casing of the electric motor. Somewhere between the motor and the gearbox is the brake which must be depressed in order to stop the motor from turning. If for some reason you cannot find this brake, use a pair of vise grips and clamp down on the inside of the blade and turn it until it stops. Now you can unbolt you blade. P.S. make sure you know if the thread is reverse or not! Good luck.
Nov 16, 2010 | Black & Decker 12" Dbl Bevel Miter Saw
Motor sounds like its running, but the blades
It sounds like a gear might of broken either under the blender jug or in the unit itself. Best bet is seek out an appliance repair shop locally.
Feb 02, 2010 | Krups KB720 5 Speed Blender
Drive gear is slipping. Motor turns but the blade fails to turn
sounds like a shear pin either on the motor or the blade assembly. If you put the blender on low without the cannister on top touch the gear on top of the unit and see if the gear slips or stops. Use a pencil or something..Not your finger. If it stoops then the pin is broken at the motor. If not, it is broken at the blade unit.
Hope this helps
Kurt
Mar 17, 2009 | Back to Basics Smoothie Jr. B Work Top...
Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Jun 08, 2008 | Office Equipment & Supplies
Hamilton Beach 80355 Custom Grind Coffee Grinder Logo
46 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
