Question about Nordic Track NordicTrack Treadmill, A2550
Nordictrac 2500 problem: when dead man key is removed, control panel lights up, but none of the functions work. With he key in place the treadmill functions normally.
  • 297 Answers
You have it in DEMO mode, your manual will show you how to disable this feature.
Have a good new year!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Jan 02, 2011
Nordictrac treadmill. My nordictrac C1900 starts and runs about 1-2 seconds , at which point the display and MCB led go off and then come back on. If i try to restart it does the same 1-2 second run then...
Hi , measure the output voltage in the
control board motor. If the voltage dissapear
in the moment the machine Stop, the problem
is the Controller B. Motor, Replace it.
IF the voltage is present
and the machine always stop, the problem is the Motor
repair or replace.
block diagram treadmills-b4mubhgzxv0l5p14byv1s0yc-4-0.png Blessing
cuadra2016@yandex.com
cell+WhatsApp:+50588611441
Apr 28, 2018 | Exercise & Fitness
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
Control panel lights up but not responsive on any function
The proform console sometimes freezes up and refuses to take the input from the user. Replace the console. The manufacturer do not sell parts for this console.
May 19, 2013 | Proform Pro Form 785ss 785 Ss Treadmill,...
Nordictrac a2250 beeps when key is attached
adjust the reed switch first, and after RUN the software calibration for diagnose and troubleshooting. see the diagram
God bless you
Jun 17, 2012 | Nordic Track NordicTrack Treadmill, A2550
When turned on right hand display comes up with 51 then flashes with the number 68. Dead man button works but not any of the controls. Alex
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 11_30_2011_12_46_08_am.gif
Try to tight the keypanel flexible cable vs Display Board and then tight the connector from display board vs Main controller board(lower board) and will be a good idea spray with contact cleaner the keypanel with carefully and patience.
Finally you will have 2 options if the problem persist: 1) display board faulty or 2) main controller board faulty. See. the block diagram how the main controller board has 90% of function in any treadmills.
Jul 14, 2011 | Avanti Fitness AT380 Treadmill
I recently got a free Nordictrac NTL1095.0 C2050 from my neighbor. it seems to be stuck in demo mode. no buttons work even when trying to get out of said mode. The console will beep when key is put in but...
well the reed switch is working but sounds like board or both check voltage coming to the console. wire harness. not sure but if it reads low controller iisue
Mar 16, 2011 | NordicTrack Exercise & Fitness
Proform Sport 1000 - The right hand side of my controls which allow me to change the speed of the treadmill do not work. The left side is still operational and allows me to change the incline and select...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Aug 09, 2010 | Proform Sport 1000 Folding Treadmill...
Treadmill will not start - say "Safe" on the Monitor
I'm not overly familiar with the Landice treadmills, although it sounds like it's not registering the safety key. Usually either a magnetic key or a slide key. Make sure your safety key is making good contact and if it's a magnetic key, that there's actually a magnet in it (sometimes they fall out without anyone noticing). If it's a key that you slide in to activate, see if there's any play in the port when you put the key in (wiggle it around) and if that works, the contact switch is slightly out of place. If the magnet is present and it's still not registering, either the reed switch inside the console has shifted and is too far away from the key magnet or it's malfunctioning (broken reed, shorted wire etc.)
Jun 01, 2010 | Landice L 7 Club Cardio Trainer Treadmill
Nordic Track NordicTrack Treadmill, A2550 Logo
555 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
