Question about Moen 4551___ Monticello Popular Two Handle Bath Faucet w/Drain Assembly
For the Moen Monticello 4500 series the hub cannot be removed. I have tried penetrating oil and a fabric strap wrench but it will no move counterclockwise. Any suggestions?
4 Suggested Answers
bearsfan7538
  • 119 Answers
SOURCE: The handle turns past the 'off' point and then
You need to hold the lever handle off and turn the bell part counter clockwise you may need a small strap wrench or rubber guard that fits on the pliers it was very common for the plastic piece inside the handle hub to break call 1-800-buymoen and they will send you new parts at no charge
Posted on Nov 15, 2009
jyackle5
  • 8197 Answers
SOURCE: how do i get at
In the link below second to last page will tell you how to remove the valve.
http://www.moen.com/shared/pdf/instruction_sheets/ins060b.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 31, 2010
packrat1948
  • 528 Answers
SOURCE: moen monticello kitchen spout does not rotate
It needs to be taken off and lubed. If you don't have plumber lube you can use vegy oil but it will not last like plumbers lube.
Posted on Feb 16, 2011
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    7700 series Moen leaks at top and bottom of base hub
    You can just replace the o-rings. You have to remove the large nut at the base of the spout. I posted a blog post -and a video about me replacing mine.
    http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
    The replacement o-ring and retainer parts were free to me. Hope it helps you.
    Aug 17, 2011 | Moen Monticello Single-Handle Kitchen...
    Replacing the handle adapter on a 4-inch moen monticillo bathroom faucet. Can't get the handle hub to unscrew with a strap wrench. tried using lime away to cut the 15 years of crud around the handle...
    Sometimes there is a small set screw located on the handle.It takes a small allen wrench to loosen it.That should enable you to remove the handle assembly.
    Jun 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
    My classmate
    Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
    Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Moen 7700 leaking at base of faucet. how do you get to o-rings
    Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
    There is also a video at the bottom of the blog post showing how I did it.
    Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
    How do i unscrew the collar from a moen montecello spout assembly. there is a lot of calcium deposit.
    I would use what is called a strap wrench it would be best. That way you do not mess up the finish on your faucet or leave marks on it from a pair of channel lock pliers.
    Sep 09, 2010 | Moen Monticello Single-Handle Kitchen...
    I am trying to replace a lever handle 84000/4500 series and i cannot locate this product anywhere. I have tried several home depot stores but nothing! can you help?
    Go to www.moen.com. Go to parts and filters, then select find replacement parts. Follow steps to identify your model. You can order parts right here.
    Jul 13, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Moen monticello shower control, remove handle
    If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
    Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
    I have a Moen Monticello bathroom faucet. I am
    Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
    Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
    Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    The handle turns past the 'off' point and then drips. This is the Monticello faucets. I can't find pictures that aren't any more than black squares at the Moen site. Have no idea on how to get this...
    Nov 13, 2009 | Moen Bathroom Sink Faucet - 4-inch...
    Moen 4551___ Monticello Popular Two Handle Bath Faucet w/Drain Assembly Logo
    1,403 people viewed this question
    Top Moen Plumbing Experts
    john h
    Don Numinen
    Don Numinen
    Mike
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
