Question about Fisher and Paykel GWL11 Top Load Washer
No power coming from machine i am pretty sure problem comes from main motherboard could you give me a price on this and where to get a replacement
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
Here is a link to the supplier and the part you requested.
Posted on Jan 02, 2011
What model motherboard is in a sony hvr-z1u camcorder and how much should a replacement part cost?
you might be running into couple of issues. first, components for sony equipment is always pretty expensive. so a motherboard for a camera being expensive isn't unlikely. also the parts for this camera are probably a bit hard to come by since the camera has been discontinued for so long. a fix and replacement part can easily cost more than the camera is worth.
Apr 04, 2014 | Sony Handycam Video Cameras
Need repairs on Technics SX-PX103-M Model.
Have you had any luck with your Technics piano? I've got the same piano and Mine does not work either. No lights on the control panel, only red power light comes on. Does yours have any led lights besides the power light that come on? I've investigated and I have learned a lot from this piano. 4 main boards. Im pretty sure I've got it down to one board. Interested in selling me any boards from your Piano??
Jan 19, 2012 | Music
My pc atx power supply is ok but when I turn it on it will open but a second will shut off again, how can I fix it? my mobo # DG31PR
You probably have some bad capacitors in the power supply.
It's probably about the same price to get another power supply as it would be to try to fix it.
Power supplies are cheap.
Mar 09, 2011 | Intel DG31PR Motherboard
Dell has informed me that the mother board and memory is shot and the power cable. i can not get power to lap top any thing i can do to fix problem
i have never found dell support any help how did they come to that dissision tell me the the make and model no.
Oct 06, 2010 | Computers & Internet
The motherboard completely stopped working - now happened on 2 machines. can they be replaced?
yes the motherboard can be replaced, however you should take into consideration the age of your PC and is it worth spending the money to replace it or purchase a new PC. The new PC's have come down in price and have a lot more power behind them. It may be worth comparing prices.
Aug 14, 2009 | Acer Aspire L100 PC Desktop
Power socket needs replacing on motherboard
Are you refering to the multisocket on the motherboard coming from the power supply or the 110 volt socket into the back of the power supply from the outside? PC or laptop?
Apr 22, 2009 | HP Compaq Motherboard
Tried new power supply but didn't help. (Who knows - maybe I didn't install correctly.) I first thought it was the power switch on front of machine. Was wondering if some easy test for power switch?
Tips from me:
1.If your power supply isn't coming on, I advise you to check the 20/24-pin motherboard power cable,
connector, and be sure it's down in tight. Make sure that lock tab of the power cable connector, snaps over the motherboard connector lug. Make sure that connector is in all the way.
2.Be sure the wires that come from the Power On switch, and go to the motherboard, are connected, and down all the way. The connector, or individual connectors, need to be down on those motherboard pins all the way. (The area on the motherboard where they connect, is called the Front Panel header. A connector on a motherboard is called a Header)
Also make sure both wires from the Power On switch, (Button), are connected to the motherboard, if the wires have individual connectors.
Now, how to test to see if the Power On switch is bad.
The 20/24-pin ATX motherboard power cable connector comes in three styles.
A.20-pin connector. Has two rows of 10 socket holes
B.24-pin connector. Has two rows of 12 socket holes
C.20-pin and a 4-pin connector.
NO matter what style it is, it has a Green wire going to that connector. The Green wire is the
Soft Power On wire.
With the motherboard power connector plugged into the motherboard, and the computer plugged into the surge protector, you need to jump that Soft Power On wire, to a Ground wire.
View these photos of a 20-pin ATX Main power cable. (Motherboard power cable, Main power cable.
Same/same)
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Look at the photo all the way to the right. (You can save this page, and bring it up in a new window)
This shows that Green wire. Fourth one from the left.
Next to it is a Black wire. Fifth one from the left.
ANY Black wire is a Ground wire.
You need to make a jumper wire. This wire should have insulation on it. It should be as thick as those power cable wires. It should be about 3 inches long. You need to strip off 3/4ths of a inch of insulation, off of EACH end. Twist the exposed wires. Make a tight wrap. Bend this wire into a U-shape.
At this point you may want to don a protective rubber glove. Tightly fitting dishwashing glove, or perhaps a surgical style one. Reasoning is, that there will be a spark. You may feel more safe this way. I don't use one, but I'm an old tech, and maybe not too Tightly Wrapped! lol! (I also was a journeyman lineman, so this spark doesn't bother me!)
With the ATX motherboard power cable plugged into the motherboard, you are looking at the back of the connector. The wires go down into a socket. At the end of every wire is a metal terminal end.
It's pretty far down in there. One end of your jumper wire, goes down deep into the Green wire socket. It needs to touch that metal terminal end.
The other end of your jumper wire, needs to touch a Ground wire terminal end. ANY Black wire is a Ground wire. Just stick the end down into a socket with a Ground wire. Hold it there for about 1 to 2 seconds, bring the wire back out. You just want to make a Momentary Contact.
Your power supply should start.
If so, you have a bad Power On switch. If not, your problem is the power supply, or the motherboard.
Apr 19, 2009 | E-Machines eMachines Desktop PC
Rear Main Seal leak on 1996 toyota camry, 6 cyl sedan automomatic
No and No,
Just find a local shop and you can get it done for around $350 for the seal and $200 for the rack and pinion.
Mar 20, 2009 | 1987 Toyota Camry
Mother board problem
The noise must be coming from the power supply. The only thing running before you press the power on button is the PSU.
Unplug the power cord on the PSU. Check the back of the PSU for a red slide switch. Make sure it is set for 115v. Than disconnect the main power from the motherboard. Plud in the power cord, (still hear the high pitch noise?). Swap out your power supply.
Mike
Apr 09, 2008 | ECS RS400-A (V1.0) Motherboard
Help!!!
There's a pretty good chance your CPU is bad.
Could also be the video card.
Oct 10, 2007 | Intel Motherboard
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
