Display screens on hitachi ax-m69 hi fi have dimmed down to nothing. they are not showing anything at all and they were bright
  • 2 more comments
  • Anonymous Sep 06, 2008
    I have the same problem too. First the Graphic Equaliser. Now can`t see and also the main panel at the top is going.
  • BENTOMHEAL Oct 25, 2008
    display screens on hitachi ax-m69 hi fi have dimmed down to nothing. they are not showing anything at all and they were bright
  • ge2kas Dec 26, 2008
    same problem here....
  • jjg_72 Mar 07, 2009
    hi yes both my sreens are very dim , you can just about see them in the dark with red coloured horizontal lines across please can anyone help
bsrjth
  • 270 Answers
SOURCE: Unable to adjust the brightness of display screen
bright ness buttons are indicted witha sun like mark . they r usaly used with fn keys look for that keys
Posted on Dec 22, 2007
SOURCE: how do i reset a
push the funtion button till dab bomes up on the screen then push in the info button and it will start to retune dab. for a total reset just push the select button 1 second after you hold the info button for 5 seconds
Posted on Mar 10, 2008
SOURCE: I have a Hitachi AX-m133
Hi
I recently got one of these and had the same problems. These were solved as follows.
Firstly, for small devices such as USB sticks and MP3 players they must be formated as FAT32 otherwise they cant be read, NTFS does not appear to be supported.
Secondly, for portable hard drives they must be also formated to FAT32 they also need to be externaly powered. For my 2 1/2" lap top drive the power from the USB port on the machine was not enough to fire up the drive I had to use a Y cable plugged into a mains usb charger to boost the power it then worked fine. Also be a little patient as it will take a little while to read the drive, this will depend on the drive capacity but you should hear the drive ticking over as it does this
Posted on Jul 12, 2008
SOURCE: Screen not bright enough
hit and hold the fn button and adjust the brightness with the right arrow. krakkerjack
Posted on Jan 14, 2009
mneilsen2084
  • 342 Answers
SOURCE: my ipods brightness doesnt work is very dim when i turn the brightness up or down nothing happens the screen just stays very dim all the time i restored the ipod and still the same
Well as you probably figure, you're back light has probably crapped out. However I would reset it by holding both the menu and center buttons at the same time until you see an apple appear on the screen. If the back light does not come on then, try the settings one more time. If there is still no backlight at this point; I would go ahead and connect it to your computer and restore it using itunes. Sadly if you still cannot resolve your issue at this point you will probably want to call apple tech support about it at 1-800-APL-CARE (1-800-275-2273) If your still under warranty they should cover all expenses on the repair or replacement. (Just don't admit to any kind of accidental damage)
Posted on Apr 22, 2009
Hitachi ax m82
Can the Hitachi ax m82 hi-fi manually adjust the bass and treble without remote control ?
Mar 21, 2014 | Audio Players & Recorders
My laptop display very dim
If your HP laptop has a dull screen, or if the screen is too bright to make out anything that's displayed, you may need to adjust the brightness to get your screen back the way you like it. You don't want to strain your eyes to see your screen, and the fix is really simple. It's about as easy as adjusting the brightness on a TV. You'll have your brightness set the way you want it in a few seconds.
1. Right-click on an empty space on the desktop and a drop-down menu will appear.
2. Click on "Properties." If the HP laptop uses Windows Vista, you'll click on "Personalize."
3. On the "Personalize appearance and sounds" screen, click on "Window Color and Appearance."
4. Click on the arrow beside "Show color mixer."
5. Use your mouse pointer to move the tab on the "Brightness" scale to the left or the right to adjust the brightness and click on "OK" when you're content with the color.
I hope you find it very helpful. Thank you for using fixya.
Best regards.
Aug 15, 2011 | HP G62144DX Laptop
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
My LCD monitor has a dimmed display
You should be able to increase the brightness by holding down the blue "FN" key and finding the blue brightness buttons (usually the up and down arrows or two of the F keys above the numbers. The brightness buttons usually look like a sun with a up and down arrow.
Mar 18, 2009 | Hitachi 14.1 IN. (1400 X 1050) SXGA+ TFT...
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
Dim backround and display on westinghouse LTV-40w1 HDC tv
u will have to go into service menu to set sub brightness be carefull u may do more bad than good write down all valus before atempting to adj.
Dec 08, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
419 people viewed this question
 Grubhead
Grubhead
