Question about Hampton Bay B552ODWH Gazebo Plus Ceiling Fan
Hello, I am not sure if this is the exact sytle of fan but the receiver is not working and I am having trouble getting to it. I have taken off the blades and the screw just below the base. Now I'm not sure what to do next to get to the receiver as nothing came apart when removing the last screw. Thank you.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
the receiver is located up at the ceiling part the upper most cover remove all base screws
you wil need 2 people for this
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Remote will not operate fan or light. Replaced battery. Remote light glows red when pressed
Check dip switches in remote and dip switches on receiver in the canopy of the fan, make sure the settings match exactly. Make sure there is power to the fan. Make sure the fan and light are not manually set to off by pullchains that may be on the fan. If the fan does have pullchains, wire it directly in (bypass the remote in the canopy) and test the functions to make sure the fan and light are working. If it works without the remote, but not with the remote, and the dip switches are set the same and you have new batteries, then the remote and receiver should be replaced.
Feb 28, 2011 | Hunter 52" Ceiling Fan With Light And...
I have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
I HAVE PURCHASED RV-V467 AMP AND YDS 12 DOCK. HOW DO I GET MUSIC AND PHOTOES TO SHOW ON TV ,ALL IM GETTING IS MUSIC THROUGH AMP AND SURROUND SOUND
To get photos on tv, you need to make sure you run a video connection from the receiver to your tv. Once you get that part taken care of, make sure your tv is set to the same input where your receiver is plugged in.
Good Luck
Jan 07, 2011 | Yamaha Audio Players & Recorders
My power supply is fine but i can't get my computer to turn on
I've experienced this problem in the past and it's a dreadful feeling. There are a few things you can try before resorting to replacing the motherboard.
Based on your question, I'm guessing that you are fairly computer savvy and have already begun troubleshooting. Even so, the simple things can trip up even the pros sometimes if they overlook the basics.
Start at square 1 and ensure that everything is as it should be:
- Make sure that all cables are snuggly plugged in (power to CPU, surge protector, wall outlet, etc.) Kids and pets can knock them loose when you're not looking.
- Make sure that all switches are turned on (back of CPU, surge protector, etc)
-If power supply has been replaced/tested and proves to be okay then consider the power button itself. It's rare but it may not be working.
-If computer turns on then back off, you may need to replace your fan.
If you experienced the computer turning on, running for a while then turning off and continued to use it anyway- then you probably had a fan that wasn't working and eventually fried your motherboard.
Let me know how it goes. I may be able to provide more assistance after receiving more information about what steps you've already taken (i.e., how do you know the power supply is okay?... what trouble shooting steps have you already taken?) The information above assumes that you are hearing no noise from the cpu, fan, etc.
Jun 24, 2010 | HP Computers & Internet
Remote control will not turn on/off fan or light. Has good battery. Where is the transmitter located on the ceiling fan?
The transmitter is the remote. The receiver is located inside the fan mounting bracket next to the ceiling. If you replace it make sure to set the dip settings on the new receiver exactly as they are on the old one. Wire the new receiver exactly as the old one is wired if it was working before.
Nov 07, 2009 | Hunter 52" Ceiling Fan With Light And...
Is it easy to change our the receiver for Hampton Bay fans
Yes it is not that hard to replace an existing receiver with a new one. Caution: Turn off the power to the fan at the service panel. Remove the cover next to the ceiling which normally will have screws on the side or on the bottom under a plastic cover you remove by turning or pulling off. Inside the mounting bracket you will see the receiver. Carefully pull it out and take notice of how the wires from the receiver are connected and how the receiver was placed inside the mount. Look at the dip settings on the old receiver and set the new receiver exactly the same. The transmitter and receiver dip settings must be the same or it will not work so it is critical the new receiver settings are set exactly as the one you are removing. Now, remove one wire nut at a time and connect the new receiver exactly as the old one was connected. Make sure to tighten the wire nut securely with no bare wires showing. Slightly pull on the wires to make sure they are secure. Tape this up with electrical tape as a security measure. Once you get all the wires connected put the receiver back inside the mount just like it was. Replace the cover and then go turn the power back on. You are done.
Nov 07, 2009 | Hampton Bay 13087 70450 Carousel II...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
FF error code
The ER-FF problem that you have is: ERROR -FAN FREEZER so it means that you have a problem with maybe the fan motor or if it's a bottom mount freezer maybe ice built up on the fan motor so it's blockin the fan motor.
Hope i helped u a little bit ! :)
Francois Pelosse
Jan 19, 2009 | Freezers
Remote control for the fan
So you have Hampton Bay fans and universal remotes? If so, then either the remotes are not programmed correctly or the receivers are not wired for the remotes. That is one bad thing about using universal remotes.
I suggest you go to Home Depot and buy one Hampton Bay remote, bring it home, turn of the breaker to the fans, and get on a ladder to get to the receiver. Check the dip switches, and program the switches on the remote exactly the same way.
(While you're at it, make sure the universals dip switches are set exactly the same.)
It should work properly after that.
Sep 13, 2008 | Universal Remote Control Hampton Bay...
Hampton Bay B552ODWH Gazebo Plus Ceiling Fan Logo
75 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
