Question about Brother DCP-7040 Laser Printer
Printer quit printing. Screen says fuser cover is open. Where is it located so I can close it?
    President:
  • 662 Answers
Your problem: paper is jammed in the back of the printer around/in the fuser.
The Users Manual for your printer is located at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users Manual/UM_DCP_7030_7040_EN_1510.PDF
You'll need Adobe Acrobat Reader (free from www.adobe.com) to view it.
LOCATION:The fuser cover is located in the back - its covered by the panel in the back called
the "back cover" aka "back output tray cover".
2-step fix:
(A) open the back cover - on the back of the printer.
HOW: it flips down
(B) open the fuser cover and remove paper jam
How: Pull the 2 tabs (one left and one right) toward you to open the fuser cover.
(it also flips down to open).
Most of this fix comes from downloading the Users Manual and blowing up page 60 (of 108 pages).
Posted on Jan 01, 2011
    Problem Solver:
  • 16 Answers
This can be caused by several things. Make sure there is no paper jam (the usual cause). If you are sure there is not one, then check the fuser cover, which is at the back of the printer. Open the door and make sure there is nothing blocking the door from closing. Close the door and the problem "should" disappear. If it doesn't, it could be a broken actuator, which would not allow the switch to register the door as closed (which I would hope is not the problem).
Hope this helps...
How to fix Lexmark T632 924 service Fuser error
924 is an open thermister error. The thermistor controls when power is actually applied to the heating lamp on the fuser. I used to have this problem with other Lexmark models and was able to replace the thermister itself. The thermister is located on the top cover of the fuser. If you have a real Radio Shack near you they should have them. I believe that the temperature should be around 400F.
May 08, 2015 | Lexmark T632 Laser Printer
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
Lsu hsync error cycle power
give back cover of the printer, which is located Fuser Fuser is carefully removed after it opened by pressing the two side screws to remove out.Se Fuser notice printed contacts are clean and in particular an electric tab located somewhere in that cloud right des.Reinstall Fuser ... success!
Apr 12, 2011 | Samsung ML-3051ND Laser Printer
Paper jammed at this time error message show on control panel 13.05.00-Jam in top cover area open front covers and Transfer unit. Fuser is hot transfer unit can be easily damaged. Check left side of...
This error comes when media doesn't come to fuser delivery sencor with in the specified time it may be due to improper paper picking or fault in registration ***...
clean the paper feed rooler & registration *** path ur problem will resolve defin...........
Jul 14, 2010 | HP LaserJet M4345 MultiFunction Printer
After my old fuser assembly wrapped and fused a sheet of paper around the rollers,I installed a new fuser. But now I get a continuing error message, "Jam in Exit Area" even though the paper path is clear,...
This error usually happens on Laser printers after removing a jam and the sensor is not correctly placed in the right location. "exit area" refers to the switch where the page exist the printer, you can find a black piece of plastic that moves, that is the "sensor". When it moves, blocks the infrared light from the photodiode. That is the source of the problem.
Perhaps the plastic part is not correctly placed so doesn't detect the paper exiting the printer OR some foreign material is obstructing the photodiode (perhaps toner? dust?).
Disassemble is required to perform a visual inspection. If everything looks fine, look for broken wires, faulty connectors (from that area).
If you don't have experience about disassembling the printer and need more assistance, please let us know.
I hope this info helps. Good luck!
Jan 10, 2010 | Samsung CLP-510 Laser Printer
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
Back Cover Open. Close the back Cover. That is
Do the following steps to resolve the problem -
1. Open the back cover
2. Pull the flap down that hides the orange roller on the fuser
(Careful it's Hot on that fuser!!)
3. Locate the thin piece of plastic that runs from the centre to the right hand side. This bar is the problem
4.  3/4 along the right hand side, there is a sticky out bit on this bar that should sit in a hole.
Once you located it properly, the 'door open' error went away.
Good Luck!!
Thanks
Jul 07, 2009 | Brother MFC-7420 Laser Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Fuser drum ?
the fuser is a rubber covered roller (located nearest the exit tray of the printer) that must get hot to work. as the paper is approaching the roller, the carbon toner is merely resting on the paper. when it reaches the roller, the heated roller presses and "fuses" the toner into the paper. now, i am not quite sure what is the real problem...does the fuser get hot? test it by turning on and waiting for the "OK" signal to begin print. then shut it off and quickly open the printer and touch the fuser (be careful!). if it gets hot, your problem is somewhere else, unless the rubber roller or the roller temperature sensor needs heavy cleaning, of course. the sensor is located under the roller cover and is touching the rubber and is identified by having two wires leading to it. sometimes this sensor is electrically ok, but carbon buildup acts as a thermal insulator and does not allow the sensor to feel the higher temperature. the printer will never reach the "OK" status if fuser not reaching the correct temperature, so you can quickly test if it is heating during the warmup period. let me know of any updates.
Oct 08, 2007 | Dell 3100cn Laser Printer
Brother DCP-7040 Laser Printer Logo
783 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
