Question about Maytag PYE2300AY Electric Dryer
How to replace an idler pulley - Maytag PYE2300AY Electric Dryer
  • Maytag Master
  • 7,482 Answers
The idler pulley bracket will mount on the base of the dryer, look for minute wear or shiny spots where the bracket has rubbed metal to metal on the base.
I will include a link for you to click on to see how to route the belt also.
Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Posted on Jan 02, 2011
Idler pulley bracket where can I buy one or is there an alternative to it
you need to post year, make, model and what engine?
also which idler pulley? I'm guessing you're probably looking at the accessories drive belt ("fan belt") idler pulley bracket.
Is this a serpentine belt.
a lot of cars use Idler and or tensioner pulleys on the timing belt/chain. the Idlers often don't have brackets
why are you replacing the bracket? did you break it? or do you just need the pulley? I normally replace both pulleys (idler and tensioner) when replacing either one.
anyways.. need a lot more info to answer your question
Dec 24, 2016 | Cars & Trucks
Belt is broke and plastic wheel is worn into .
plastic wheel = Idler pulley
a bad bearing in your idler pulley may have stopped the idler and broken your belt to repair replace idler pulley and bearing and belt
Apr 05, 2008 | Dryers
HDo I remove and install an idler pulley on a 2005 Toyota Camry?
How to replace drive belt tensioner Toyota Camry - YouTube
? 4:26
https://www.youtube.com/watch?v=gfSJvN-CE2E
Feb 22, 2013 - Uploaded by Fix It Angel
2002 2003 2004 2005 2006 2007 2008 2009 Toyota Camry. Engine, 4 cylinder, 2.4L, 2AZ-FE. 2004 Toyota ...
Idler Pulley, How to replace (EASY and CHEAP) - YouTube
? 4:56
https://www.youtube.com/watch?v=axAltpW8wR4
Nov 2, 2013 - Uploaded by ChrisFix
Idler pulley squeak? Learn how to fix a squeaky pulley in your car. The serpentine belt in your car powers the ...
2007 Camry Serpentine Belt Replace - 4 Cyl, 2.4 liter ...
? 4:21
https://www.youtube.com/watch?v=ejhyCrh96a8
Jan 13, 2013 - Uploaded by Flyin Brian
I show you step-by step how to get the old belt off and install a new ... ... Water pump replacement 2007 Toyota ...
Jan 27, 2016 | Toyota Cars & Trucks
How to remove front idler
Dryer Idler Pulley (part #691366)-How To Replace - YouTube
? 6:06
https://www.youtube.com/watch?v=YoJ7k30kXhE
Nov 14, 2011 - Uploaded by AppliancePartsPros
Buy the new Dryer Idler Pulley 691366 ... We did not have toremove the rear panel with this design, it was ...
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ...
? 2:53
https://www.youtube.com/watch?v=RZ09dH4-7Ho
Jul 6, 2010 - Uploaded by RepairClinic.com
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ElectricDryer Repair .... If the belt is around the drum ...
Dryer Idler Pulley Replacement - GE Dryer Repair (part ...
? 3:37
https://www.youtube.com/watch?v=bm8s2vVuxvk
Sep 17, 2012 - Uploaded by RepairClinic.com
The most common reasons for replacing the idler pulley... ... GEdryer tune up, belt, drum bearing and front ...
Dec 25, 2015 | Dryers
How to reinsta l idler pulley arm
Commercial Mower Maintenance-Replacing Idler Pulley ...
? 3:44
www.youtube.com/watch?v=io2aCjM0o8Y
Sep 30, 2011 - Uploaded by askanthonynow
After new bearings were placed into an idler pulley, it is being installed on the deck of the mower. This is the .
How to Replace the Deck Idler Pulley on a Troy-Bilt Pony ...? 8:04www.youtube.com/watch?v=HY9AuNe5DWAAug 13, 2013 - Uploaded by eReplacementParts.comThis tutorial will show you how to remove and install the idler(4.25") pulley on a Troy-Bilt Pony lawn tractor/riding mower. Helpful items include ...How to Fix the Idler Spring on a Zero-Turn Mower ' Home ...
Nov 01, 2015 | Yard Machines Garden
How to install a idler pulley
Hello, Need more information on this in order to help you with getting help installing the idler pulley. What is the device you are changing th pulley too?
Sep 30, 2014 | Gates 36220 Idler Pulley
What is the belt diagram from the deck to the motor for a mower?
1st, Unplug the Dryer from the Power Supply.
You will need the Exact recommended Replacement "Idler Pulley".
With the Belt Ribs Facing Toward the Dryer Drum, position the belt on the tell tale Ring Mark on the Drum letting the Belt Hang Down below the Drum.
Place The New Idler Pulley into the Slots on the Inside Dryer Bottom located near the Motor Mounted Pulley.
(Face The Idler Pulley Toward The Motor Mounted Pulley)
(Hold the Idler Pulley in place in the slots)
Take the "Hanging Belt" & run the Whole Loop "UNDER" the Idler Pulley & then
Attach the "Belt Loop" "AROUND" The Motor Mounted Pulley.
That should do it.
Put the rest of the Dryer Back Together...Done!
Good Luck,
Vinnie
Sep 20, 2014 | Dryers
I have a 2000 gmc Jimmy . I'm going to change the
Locate the idler pulley to the left of the crankshaft pulley. The idler pulley bolts to the idler arm. The idler pulley is replaced with the arm because they are sold as one unit.
  • 2 Place a 3/8-inch ratchet driver into the square hole on the face of the idler pulley and pull up on the handle. This releases tension on the Sonoma's serpentine belt. Pull the belt off the idler pulley, lower and remove the ratchet handle.
  • 3 Remove the two bolts that secure the idler arm to the engine block using a socket and ratchet, and discard the old idler arm.
  • 4 Place the new idler arm against the engine block and secure it using the socket and ratchet.
  • 5 Put the ratchet driver into the square hole on the new idler pulley, pull up on the handle and place the serpentine belt over the pulley.
  • 6 Lower and remove the ratchet handle.
  • Oct 15, 2011 | 2000 GMC Jimmy
    Replace idler arm pulley
    An idler arm is a steering component found on vehicles without rack and pinion steering. Your referring to an idler pulley. To replace: remove the belt, remove the bolt from the center of the pulley, replace the pulley and reinstall the belt.
    Apr 11, 2009 | 1999 Dodge Intrepid
    My Whirlpool dryer belt broke.
    You should be able to reuse the idler pulley unless it is physically broken.
    The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
    Let me know if you need more assistance.
    Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
    Maytag PYE2300AY Electric Dryer Logo
    37 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
