Question about Western Digital My Book Essential 320GB External USB 2.0 - WDH1U3200N Hard Drive
What power supply worls for the model wd32000i032. I have mixed power supply adapters and am not sure which one go's with the power book.. thanks
Power supply is a brick with 4 pins. Total rating 19v, 9.5A. The 4 pins are two +19V and two negatives. Question. Why not use two 19v 4.74 adapters?
Feeding an electronic system computer or other devices from multiple external power supplies is not a good idea if you do not have any electronics knowledge. You would need to make sure that one does not affect the other. This is not a simple task to explain through fixya. There are a lot of things to take into account. When you mix two adapters that have their own voltage regulation control mechanisms, you never know when you hook the two of them together, what may happen. Even internal power supplies with multiple voltages do not join their outputs together. I understand why you may be thinking of doing this. Adapters with lower current capabilities are less expensive than an adapter that is twice the amperage. But trust me, you do not want to risk damaging your expensive electronic gear to save a little on the correct adapter.
May 12, 2016 | Computers & Internet
How could I get a adapter for my Xbox
order from amazon just make sure of the model BRICK(powersupply) you have.
Amazon com xbox 360 power supply make sure what model there are a few styles
Amazon com xbox power supply
Amazon com xbox on power supply
Feb 19, 2015 | Computers & Internet
I mixed up two power cords of My book essential external hard drive and WD TV live. Can I use them interchangable ? If not, how can I recognise which one belong to each of them? The on off power button...
You definitely want to keep the correct power adapter with the correct device. It may seem to work just fine but if the adapter does not have the ability to pull enough amperage, your device will eventually stop working. To be safe, if the voltages are identical, you should use the adapter with the higher amperage on either device. The devices only pull what amperage they need. If you plug in the wrong adapter and it has too much voltage then your device will likely be damaged also.
You can generally enter the information of the adapter (The information on the sticker, like "model dsa-31s fus") into google and you should be able to see what the adapter is for.
Aug 31, 2011 | Computers & Internet
I bought an Acer netbook last week. Love it. Today, I am in Germany and it will not charge. I have an adaptor, but the charge light on the netbook does not come on at all. It boots up fine from the...
Most power adapters are able to run the Euro 220v @50/60hz but make sure. The "Input" side should say 110-240V and 50/60hz if it says only 110v and 60hz then you power supply will not work in Germany. Also check to see if the "output" on your power cord is the same as what is your laptop is. I have mixed up power adapters before and it will simply not work. If you try and plug it in it will fry it. If you have to grab a new power adapter the best store i can think of is a place called Saturn Electronik kinda like Germany's Best Buy. It has a hazard orange sign most times.
May 09, 2011 | Acer (56.04145.901) (5604145901) Power...
Hi this is the problem.... my model is pcg k23 series.... the problem is every time i turn on my note book laptop it.... the power supply charger keep on over heating? i dont what is costing the problem? i...
The Power supply or AC adapter over heates if there is any power flucations. Try installing the BIOS update released for the Computer once. However, this is more related to AC Adapter only
Jun 30, 2010 | Sony VAIO PCG-K23 Notebook
Need a replacement power cord for harmon kardon sound sticks II
Hi
please look at your dameged power adabtor suplay it gives you all specification ,like, voltage, amp nad so on, and go to electornice retailers like radio shack ,and............ you can find replacment for it .
make sure have your old one with you , or manual book that came with your spekers.
please let us know if need more assistanse.
Thanks:Marco
Dec 13, 2008 | Harman Kardon HK206 Computer Speakers
Entrega Hub 4U
The adapter that works on my machub4u y Entrega Technologies has a output of +5VDC at 2.5A with the inner post being positive and the barrel being negative.
Sep 01, 2008 | Entrega (HUB-4U) Networking Hub
Disney mix STICK jam stand: power supply and audio cable
You can use a USB cable that psp uses and cable for aidio can be purchased at walmart
Feb 13, 2008 | Disney Mix Max Digital Media Player
Western Digital My Book Essential 320GB External USB 2.0 - WDH1U3200N Hard Drive Logo
141 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
