Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Spin does has stopped working. all the functions work normally but the washer has stopped spinning.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Here is a link to the part you will need.
Posted on Jan 02, 2011
harley12
  • 22 Answers
SOURCE: GE washer spins slowly -Clothes still wet
Doesnt make any sense why the motor goes off and on. If I read your email correctly. some typos on your email. but, sounds like the belt is too big. Or the spring device that keeps the belt tight is not working properly. You need to make sure what ever it is that keeps that belt tight is working properly or not damaged. The belt is very important to making the spin work good. Match it up with your old belt. The old belt will be slightly longer because of being stretched over a period of time. Get your unit number and model number and go to your nearest dealer and get the correct belt.
Posted on Sep 18, 2006
MNTECH
  • 1543 Answers
SOURCE: GE WASHER WWSE6260B2WW
The most common reason a GE washer will not spin is that the water level tube has a bunch of goo in it. When the washer pumps out, the air does not escape past the goo, and the washer thinks it is still full of water, and thus it will not send power to the motor to spin.
Pop the front off the machine with a putty knife at the front top seam and pull the clear tube off the left front side of the outer tub. Usually it is easiest to just cut off the first inch of the tube (where the goo is) and reattach, however you may want to clean the tube end and the hollow nipple it attaches to with a thin wire. This problem is seen most often with consumers who rarely if ever use liquid bleach. If you don't use bleach very often, filling to the lowest water setting with the hottest water possible, and a strong concentration of liquid bleach, then running the washer through a cycle (no clothes) every 6 month or so should prevent the problem from reoccouring.
Posted on Aug 28, 2008
  • 530 Answers
SOURCE: KitchenAid Washer with no spin
Hi, so you have a kitchinaid washer that is not spinning and making a horrible noise.
More than likley you have a bad drive coupler. Which is located if you tip the unit back. not all the way, just enough to see the inerds of the washer. I usually prop it against the wall. There is your pump and attached to the pump is your motor. Between the motor and the transmission is your drive coupler. take the pump and motor off to gain acces to this part. there are 2 clips for the pump and 2 clips for the motor. usually 2 screws holding the clips for pump 2. Take the motor off and you will see the coupler. there is a grommet that goes between the 2 pieces sometimes that gets worn out and you will see black soot on the ground. That's a good indicationg that the coupler is the culprite
Posted on Jan 05, 2009
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
  • 67 Answers
SOURCE: Admiral Washer........Spin cycle not working.
BAD LID SWITCH
Posted on May 18, 2009
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Duet has no spin cycle... stops at 2 minutes or is 2 an errorcode
I atill don't understand, because my machine it no work at all, when i keed supply power machine nothing work has only red flash light alarm on the spin function?
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Our hoover ultra care 1300 large load washing machine spin fault
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Danby spin / washer
Danby DTT420 W
Mine just stopped working on gentle cycle and will only go fast in one direction on normal. Worked fine when I put it away.... :(
May 18, 2008 | Danby DTT420 Top Load Washer
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Sep 18, 2006 | GE WSXH208A Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
