Question about HP Photosmart Premium C309A All-In-One Printer
I have a HP Photosmart C309. I want to scan something to my computer. When I choose scan to computer I get the following error message: "try starting scan from computer. Refer to documentation for details." I have powered off the maching. Used the set up wizard to make sure the network was set up and recognized. I am able to scan to a USB drive but want to be able to scan directly to my computer. Please advise. Thanks Tami
nliwilson
  • 114 Answers
SOURCE: HP Photosmart 2575 scanner / copier
The most common causes of this issue are 1: you do not have the software installed on your computer (or you need an updated version form the HP web-site) and/or 2: you are connecting to the printer over a network and your firewall is stopping the printer from accessing the HP software on your computer. A little more info would be helpful in diagnosing the problem; What Operating System is your computer running? Is your computer connected to the printer via USB or over a network? Do you have the latest HP software installed? Do you have more than one printer, scanner or all in one device connected to your computer? Has the printer always had this problem or has it worked before?
Posted on Aug 16, 2007
  • 35 Answers
SOURCE: Wireless HP 6180 PhotoSmart All in ONe will not scan document to my computer
hi..!
- pls click this link below it might help you to troubleshoot the problem
- http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01391654&cc=us&lc=en&dlc=en&product=1153494 - for VISTA OS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01388134&cc=us&lc=en&dlc=en&product=1153494 - for XP OS
Posted on Jul 30, 2008
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
SOURCE: HP 5280 Photosmart won't print??
I replaced my ink cartridge on my HP 5280 Photosmart. Now it says, "refer to printer documentation". What do I do?
Posted on Jul 13, 2009
SOURCE: Scan error with HP Photosmart C4480
Please try "Scanners and Cameras" which comes with Windows to see if you can scan images successfully from your scanner.
_______________________________
Catherine Sea
Dynamsoft | TWAIN ActiveX/Plug-in
Posted on Jan 07, 2010
Hp c309 all in one, does not respond to the computer when scanning
Kindly unistall the drivers of Hp c309 and reinstall it again on ur computer..........
problem will solved......
Aug 31, 2011 | HP Photosmart Premium C309A All-In-One...
I keep getting this message every time I want to scan something to my computer. "Scan Problem: Try Starting scan from computer. Refer to documentation for details."
Go to printers and Faxes in Control Panel Right Click the Printer, Select Properties Select Ports from the top tabs and make sure "Enable Bi-Directional Support" is selected.
Also check the HP ImageZone software settings to make sure the computer knows what to do when you scan directly.
This message is usually caused because the printer can not talk to the PC or does not know what to do with the scan.
Regards GM
Apr 05, 2011 | HP Photosmart Premium C309A All-In-One...
Photosmart c309 Tried loading drivers and
Since you have problem loading driver using the setup disc that came with the printer, there's a chance here that some part of the installation disc are corrupted so it will be better if you use the printer software from HP web site, download it from this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3737193&lang=en&cc=us&prodTypeId=18972&prodSeriesId=3737192&taskId=135
Mar 09, 2010 | HP Photosmart Premium C309A All-In-One...
I have an HP photosmart premium fax C309 series. It is connected to a mac but the scanner function will not work. It gives a preview and then says an unknown error occurred. I tried uninstalling and...
Hello
Based on information you have provided I understand that you have problems with your Printer. I realize the inconvenience it may have caused you. I will provide my best information to get a fix for this issue.
As per my analysis,
Issue : Mac OS : Scanning with HP Scan Software
Printer : HP Photosmart Premium Fax All-in-One - C309a
OS: MAC
The solution for the issue you described is provided in the online HP knowledge-base article Link :
I Cannot Scan on MAC
Setting up and using the Product
Scan Does not start
Thank you,
Cheers
Tejodhar Atreya U
Jan 04, 2010 | HP Office Equipment & Supplies
Catherine Sea
Feb 24, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP product assistant
Contact HP for Care at 1-800-585-2494
Feb 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart Premium C309A  All-In-One Printer Logo
251 people viewed this question
Seeker5211
Seeker5211
