Question about GE (PSS26MSRSS) Side by Side Refrigerator
Smell strong odor around the refrigerator. the manual seems to point out to problem in the drainage area. need more specific help.
  • 29 Answers
Check the fan located on the lower back side of the refrigerator to make sure it is free from dust or lint
Posted on Jan 02, 2011
Strong Odor when running
The smell is coming from the condenser heating up which should be located all around the outside of the box. When it is in pull down from being warm the condenser will get very hot and the smell would be the spray foam and any other chemicals in the vicinity heating up. When heated up to a certain point they will off gas and you may get a smell. After a little wile the smell should go away for good.
Mar 27, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
The freezer part of my refrigerator started to have an odor around the holidays. Since then, we have cleaned it several times. The smell/odor still exist quite strongly in the freezer section. It is not...
Hope you would have cleaned fridge and started using immediately. Don't do it.
Power off. Takeslightly wet cloth (dipped in soap water) andclean all portion.And after 5 minutes clean with dry cloth. Keep fridge door opened for minimum 6 hours to allow fresh air passing into fridge compartment. And then place foodsin airtight containers to prevent the transfer of odors. Now close fridge door and plug power.
Hope, it's helpful.
Jan 29, 2011 | Kenmore 63074 Top Freezer Refrigerator
I have a problem with an older model (?) Kitchenaid side by side BUILT-IN refrigerator/freezer. There is a perasive odor (like toxic fumes...a pungent, rather a medicated odor that is extremely noticeable...
refrigerant doesnt have a smell hmm only thing I can think off try to look at the light at the top of the fridge did it melt the liner or plastic cause its a common problem with very strong toxic smell
Nov 04, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
Foul burning odor
you could possible be right on if your frig has an electronic disp control put your nose their and sniff if seem close to what you earlier smelled you solved your problem pcb control '
Aug 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Foul dead animal smell from kenmoore side by side refrigerator/ice maker
I'm sorry that I don't have a solution, but we have the exact same problem with an older model KitchenAid side-by-side. Did you get this problem solved? If so, can you share what you did?
May 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Norcold 982 will not get cold.
If the there is a strong ammonia odor and no cooling, then you probably have a leak in the system somewhere. These types of absorption units must be repaired in a specialty shop. The most common place for a leak is the condenser coil, but can also be the evaporator inside the unit, if the odor seems to emanate from that area.
Apr 06, 2009 | Refrigerators
Door inside and metal vent area smells strongly of fumes
Did you find an answer toyour question?
My microwave smells also of petrol in the same areas.
Jun 05, 2008 | GE JVM1653 Microwave Oven
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
55 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
