Question about Microwave Ovens
A pan stuck to the glass top on the front right burner when the burner was on. When I removed the pan it took a couple of chunks of glass with it. Now there are two chuncks of glass missing from the stove top.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
You are not going to like this, and you did not give the model number of your unit. But glass replacement tops, will range from $600.00 to $800.00 just for the glass top. and their is not a way to make repairs, because it is a special glass.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
How do i replace sharp microwave turntable coupling?
No need to remove turntable motor.
1. Just remove table
2. Pull and twist the coupling. It seams stuck but it will come out from the top.
3. Twist and push the new coupling down, line up with the motor shaft and push down further.
Sep 03, 2016 | Sharp Microwave Ovens
Replacing the ceran glass maintop
Actually if you've removed the 2 or 3 screws at the front (underside) of the cooktop, you can lift up the front. Prop it up with a board, and then remove the 4 screws that hold the 2 brackets that hold the 4 elements to the cooktop. Now pull the cooktop forward a bit, and you should see a green ground wire attached to the back of the cooktop. If not, then don't worry about it! Just pull that cooktop up and off the range. You will need to transfer the 2 tabs in the back of the cooktop, and the silver steel bar located at the front of the top to the new cooktop. Then reverse the process to install the new cooktop and re-fasten the elements to it.
Apr 22, 2014 | Kenmore Microwave Ovens
Can visionware go in oven
The short answer is YES!
In the 1990's Corning produced a series of Visions cookware, brown amber and cranberry colored glass-ceramic dishes and casseroles, that had the same basic properties of its white Pyroceram cookware. Visions cookware could go directly from freezer to hot oven to stove-top to the microwave oven to table to fridge to the broiler to the dishwasher, etc. Extreme temperature changes did not affect the very durable cookware, While many folks mistake Visions cookware for Pyrex bake-ware, they are not the same. Visions cookware was never issued in the forms (square pans, rectangle baking pans, loaf pans, pie pans, etc that clear glass Pyrex baking pans had been produced in for decades. In any case, Visions glass-ceramic cookware could go direct from the freezer to the hot oven - there would be NO DAMAGE to the cookware in such a practice. Visions glass-ceramic cookware also has markings to indicate usage. The majority of Visions cookware were of the "stove pot" design - stove top was intended from the start. However it is practical to let the food defrost first, or adjust the cooking time in order to create a better thoroughly cooked dish.
Yes, Visions cookware can be used in the oven! One caveat is that the pot lids are Pyrex which means that the pot lids can not be placed under the broiler (who does that anyway?), or under direct heat, or while hot on wet surfaces. The pot lids were meant to be pot lids - just like other Pyrex glass pot lids on most cookware.
Apr 17, 2014 | CorningWare Microwave Ovens
My Siemens HF759 (Stainless steel) front has come away from the glass and is only hanging via the top of the glass by the handle. How do I put it back?
You can remove the front glass and trim by removing the two torx screws at the top of the door, they are the ones next to the prongs that stickup from the door when open. Once these are removed the door front lifts up as the bottom is only hooked on. It looks like you need to remove more screws but you don't. A two person job as the door needs to be held in the nearly closed position as you lift off the front. Once you have the door off remove the two screws holding the handle on and it is then just the glue holding the trim on which in your case and mine has failed. I googled for oven door glue and found a very good site which has excellent instructions and video for application. The biggest hassle was cleaning off the old glue (scraper and acetone) and making sure it was aligned correctly before gluing, I used masking tape for a few dry runs as you only get one chance with the glue and it goes off quickly. Hope this helps.
Oct 08, 2013 | Siemens HF87950GB Convection Microwave...
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
I have a maytag super capacity plus stove and need to adjust the air mix for the burners. How to do it? Please help thanks
Open the top of the range. I believe there are a couple of spring clips in the front between the range top and the top of the door. Not sure on the Maytag. However, when you get the lid up, (it should be hinged at the back), set the burner pieces back on. (These burner pieces HAVE to be there or you'll just have a blowtorch pointing up!) You'll see that going to every burner there is a tube to carry the gas. on the side of every tube there will be an adjustable, sliding air vent. They are usually held in position by a set screw. Loosen the set screw. Light the burner and carefully slide the vent closed or open to adjust how much air is being brought into the mix. If the flame is way too high and or orange in color....you have too much air. You want as much flame as possible on high without the flame being orange or white-ish. Once you get the flame the way you like it, tighten the set screw back. Hope this helps.
May 15, 2011 | Microwave Ovens
Ovens will not work, glass top burners do
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 15, 2011 | Microwave Ovens
Tin foil was melted to the top of one of my wife's and my electric stove burner coils. I was able to remove most of the foil but there is still some stuck to the burner and will not come off from scraping...
Use a fine grit sandpaper. Don't scrub too hard, you may scrub through the heating element. Take it slow and easy -- may take a while.
Charlie
Feb 05, 2011 | Microwave Ovens
Spacmaker xl sensor
Same goes for me. I can get most of the trim off but not the area near the hinge. ! It will cost $100 for GE to come out, and I already own the new handle. Come on GE tell us the secret.
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
