I connected the speakers but can get no sound. I've hooked the wires into the back speakers connectors - one into the red and one into black, then I hried both into red, and then tried both into black. NO SOUND. No problem with power, making setting changes..I tried radio then I put in CD. I see cd SPINNING - AGAIN NO SOUND
  • 4,924 Answers
Take a look cause the device may be on mute ..if it has a mute button be sure it is in the correct position
Be sure you plug the speakers in the out-put ...audio out-put ..and after that raze the volume ...and be sure is not muted..
Posted on Jan 02, 2011
Please send me a diagram of how the wiring is to be set up on the back of the speakers
The red connector on the speaker should be connected to the Pos.(+) connection on the Receiver/Amp. The Black to the Neg. (-) connection. ( for the proper speaker) Front Left, Front Right,etc. All, or most paired wire has either a black stripe,different shape on one,or different colour wire(silver/copper) So if you hook up the Blk striped or silver to the Neg.(black terminal) on the speaker, do so at the other end (receiver ) If both speakers aren't hooked up the same, they will work, but there won't be as much Bass because the speakers will be out of phase.(when one speaker cone is moving out,the other will be moving inward.
Dec 03, 2011 | KEF Audio Model Three Main / Stereo...
Splice Bose speaker to connect to receiver
Each speaker has two 4 Ohm drivers. Each speaker has a connector with 4 pins. From left to right they are + - - +. Say 1 2 3 4 . If you want a 8 Ohm speaker connect 2 and 4 together. Now 1 goes to your amplifier (+) and 3 to your amplifier (-). In yor case join black with blue. Now red goes to the amplifier red and green to the amplifier black.
Nov 27, 2011 | Bose Cinemate Digital Home Theater System...
Just want to know how to hook up speakers
On the back of the Technics Receiver you should see black and red speaker connections where red is positive and black is negative. One the back of the speakers you should see similar places to connect the wire, with speaker wire stripped at each end, you should attach one end to the speaker and the other to the back of the speaker corresponding with the black and red (negative and positive) connections.
Hopes this helps, feel free to ask me any more questions
Jun 18, 2011 | Technics Audio Players & Recorders
I have a Marine Model M235 and need the wiring instructions. I removed a old cassette and hooking up the Clarion CD/Radio. It is getting power but no sound from speakers. This unit has more wires than...
Common wiring for 2 speakers should be.
gray is Rt. +
gray with black stripe is Rt. -
white is left +
white with black stripe is left -
Black wire with crimped connector end is ground for deck. (battery -)
Red wire goes to 12 volt + source (fused) usually connected to ignition/accessories.
yellow goes to constant 12 v + for radio memory.
orange with white stripe, is for illumination. (connect to light switch)
blue is for power antennae if you have one.
May 22, 2011 | Clarion M235-RET CD Player
How to hook up
Hi, I can help. First of all it's not as hard as it looks. the last thing you will do is plug it in by the way ( this prevents any popping noises while hooking it up. We'll start with speakers, standard table lamp wire will do fine ( sometimes called zip cord) it is also usually polarized for you ( one of the two sides of the wire will be a little ribbed and the other will be smooth ) this makes it a little easier to keep speaker polarity correct( i usually go with the ribbed wire as hot) always make sure the positive(+) on the receivers speaker terminals are connected to the same on the speaker( the stereo and speakers will almost for sure be marked with red and black to help with that-red being + and black -) Next hook up something to the antenna terminal on the stereo for radio reception-the terminals will be marked 75ohm and 300ohm, if you do not have an antenna for this or don't listen to much radio not to worry, I find just a simple little wire bread tie with some of the plastic end stripped off works nicely for most local stations ( you will know when any antenna you try is connected by the fact you will stop getting just static.) Next connect whatever you want to listen to through your stereo, example: a dvd player can be connected with the dvd players " AUDIO OUT " going into the receivers connection for dvd (these are called rca connections-and are typically red and white plugs at both ends) also if listening in surround mode you can hook up a single rca cable to the orange connector on back of dvd player ( marked maybe as " DIGITAL PCM/LPCM " or simply " COAXIAL"the other end goes into the same connector on back of receiver. If no orange jack you may have a squarish looking connection called simply " DIGITAL IN " there may be a few of these, ones for satellite,cable,t.v. etc. These are called a "TOSLINK" connector, they are a rather stiff fiber optic cable with squarish ends that plug into the source with the surround sound output ( example when dvd player is playing the toslink jack will be lit up a little with a reddish light) same with a tv's digital output as well as cable/sat box's digital out. so that about wraps it up-just connect what you want to listen to with either rca cables or the toslink connectors-output of device being played to input on back of stereo. And if you need to connect up a recorder of any kind hook up recorders "LINE INPUT" to receivers " REC OUT" rca jacks. Thanks for choosing FixYa, I hope this helps,write back to let us know how we did or if we can be of more assistance. Good luck, Prodzilla
Apr 15, 2011 | Audio Players & Recorders
How do you hook up the speakers to a receiver. It has duel inputs. Is it two separate channels, or what?
Hello,if the speaker has 2 red and 2 black connectors then its designed to have an option for bi-amping and or bi-wiring.If you dont intend to do either than simply connect the reds together with a speaker wire and do the same with the blacks(if there is already a metal post connecting them than dont do anything but connect your speaker to the reciever as usual.
Jan 19, 2011 | Digital Audio DA-600SL Main / Stereo...
How do i hook up the speakers?
If your sound card has only pink, green and blue colors connectors in this case you will connect your speaker’s green cable into the green connector of the sound card. (Orange and black connectors will not be connected)
You will connect your microphone (if you have) to the pink connector of your sound card.
Please find the pictures which explain the color codes below:
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Logitech X-530 Computer Speakers
How do I hook up the bare wires speakers to the back, sound is coming out not good.
Sounds to me like you might have the polarity reversed. Meaning you might have hooked the positive to negative and the negative to the positive. Positive will will be red negative will be black on your receiver. On the speaker wires negative will always be solid black. Positive could be solid red, black with a red stripe, or black with any color stripe. Make sure you have solid black hooked to black and the other hooked to red. Hope this helps:)
Nov 30, 2009 | Insignia 200W Stereo Receiver
How to wire KD-S741R CAR STEREO - WIRE COLOURS ???
older pioneers:
2 x green (1 with black tracer) left rear spkr (black= negative)
2 x white (1 with black tracer) left front speaker
2 x grey (1 with black tracer) right front speaker
2 x purple (1 with black tracer) right rear speaker
Lower connector
1 x red ignition (switched supply)
1 x blue antenna output power (may not be not used)
1 x yellow Illumination (radio button lighting)
1 x orange permanant Battery supply
1 x black vehicle GND
If still not working swap yellow and orange wires! will not cause damage
May 12, 2009 | Car Audio & Video
External speaker hook-up
Ok, after A LOT of internet research I could not find any solution. So I decided to do a "chop suey" connection.
Went to Radio Shack and bought ...
Insulated Grip 2-1/4"Alligator Clips w/screw terminals 10 (five red & five black)
(A smaller alligator clip can be used if you have a soldering iron to connect the wires.)
30-Ft. 18-Gauge Clear 2-Conductor Speaker Wire
It cost about $15 for everything. Be sure to have electrical tape as well.
Stripped speaker wires to fit through each alligator clip and twisted it around the screw terminals of clip. Tapped screw terminal to cover wiring. Do this for 2 black and 2 red clips.
To install l laid the TV on its back and insterted each alligator clip to firmly fit on each terminal. Because the clips are large it will be a tight next to each other. Be sure to test one line and speaker first before completed the second line and speaker.
GOOD LUCK!
Nov 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
 Grubhead
Grubhead
