THERE ARE 2 FUSE BOXES, 1 UNDER THE HOOD & 1 INSIDE THE CAR. TURN ON IGNITION SWITCH TEST EACH FUSE WITH A GOOD FUSE TESTER. FUSES CAN BE TESTED WITHOUT REMOVING THE FUSE FROM THE FUSE BOX. THERE ARE TEST POINTS ON EACH FUSE FACING OUT. POWER ON ONE SIDE OF THE FUSE, FUSE IS BAD. POWER ON BOTH SIDES OF THE FUSE IT'S O.K.
Ihope this will help with the headlights, but the fob problem, i'm afraid, is not connected with that. Try to chek all the fuses and the batery in the fob. If the fuse changing helps with your problem and after som time the fuse is blown again, than go to the proff.car service for diagnostics. You can't keep changing fuses, you need to find reason what's causes that fuse blowing.
